fob key mania
Old Oct 9, 2013 | 06:21 AM
rayclark1's Avatar
Default fob key mania
Anyone enlighten me. I may well be missing the point - I have two keys for my Jag, but only one of them works at a time. If I program the spare the main does not work and vice versa. Is this the way of things ??????
Old Oct 9, 2013 | 07:54 AM
Not by design!
The sequence I have for X-Type programming is:
1 Insert key into ignition
2 Turn key to 'I"
3 Turn key "II" and back to 'I' quickly 4 times
4 Alarm system will chime once when key is back to 'I' for the fourth time
5 Remove key from ignition
6 Press any button on each key fob and alarm system will chime for each fob if it has been programmed correctly
7 Press unlock/lock/boot etc to make sure everything works
NOTE: every fob you have must be programmed at the same time although you only need to use one key in ignition.
Old Oct 9, 2013 | 08:19 AM
plums's Avatar
small clarification using different wording ...
all fobs and keys to be used on the vehicle must be programmed during the same session.
any fob or key that is not programmed during that session is dropped from memory.
this is a security feature that is intended to account for lost fobs or keys.
Old Oct 9, 2013 | 10:48 AM
rayclark1's Avatar
Default thanks for not fobbing me off !
I am most grateful for this advice. I assume I can now go and reprogram my keys together, using the ignition sequence outlined in this forum many times.
Old Oct 9, 2013 | 10:53 AM
rayclark1's Avatar
Default crystal clear
Thanks Graham I am now crystal with this.
Originally Posted by GGG
Not by design!
2 Turn key to 'I"
Old Oct 9, 2013 | 11:24 AM
rayclark1's Avatar
Default fobtastic
Okay Guys
Mission completed two keys operational - I am very pleased to arrive at this position, should I lose a key then I have the spare. Ten out of ten for the Forum.
Old Dec 31, 2013 | 02:03 PM
lwhitney79's Avatar
hi , do you know if this is the same for the S type r fobs/keys ?
cheers
Old Dec 31, 2013 | 02:28 PM
'fraid not the S Types are dealer or specialist programming only.
Don't forget that intro in the new members section!
philwarner
28
Jul 11, 2017 10:21 AM
redxk8
Sep 30, 2015 08:18 AM
Listers
Sep 30, 2015 07:45 AM
Jzar
Sep 27, 2015 02:55 PM
