Leicester Jaguar Ball Joint Replacement
Old Oct 19, 2012 | 01:16 PM
Mr Greene's Avatar
Default Leicester Jaguar Ball Joint Replacement
Hello I took the XJ8 for an MOT today and was surprised that she did not pass. Only 3000 miles since last MOT. Anyway front balljoint replacement and they want 240. I thought that was rather dear. I am a bit skint at the moment. What do you think?
Old Oct 19, 2012 | 01:38 PM
Welcome to the forum Mr Greene,
Assuming the only work involved is remove / replace balljoint followed by an alignment check, it is rather expensive.
Are you looking for advice on replacing it yourself?
When you get a moment, please follow this link to the New Member - Intro a MUST section New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome with advice on how and where to post tech questions like this.
Old Oct 19, 2012 | 03:43 PM
Fraser Mitchell's Avatar
What ball joint is it ? Actually it doesn't look too bad for either of the two ball joints, if that is labour and parts. Isn't Leicester Jaguar the Sturgess dealership, one of the few independents left as main dealers ? There will no doubt be 20% VAT on that too.
Old Oct 19, 2012 | 04:54 PM
Mr Greene's Avatar
hello it is front right
Old Oct 19, 2012 | 06:03 PM
Upper Balljoint (item 5) or Lower Balljoint (item 6)?
With the Upper, it's normal to replace the fulcrum bushes at the same time or the complete Upper Wishbone if it is badly corroded.
Attached Thumbnails Leicester Jaguar Ball Joint Replacement-xj8-front-suspension.jpg
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
Nati
May 16, 2020 08:30 AM
Steve Langridge
Sep 3, 2015 07:35 PM
dpappyp
Aug 27, 2015 06:31 AM
