US Lower Atlantic NC SC FL GA
Paint source question
Old Jun 20, 2021 | 05:48 PM
Sardonicus's Avatar
Default Paint source question
So I am making a rather long to-do list and paint is going to be inevitably on my list. So far I've only found 1 source with the sovereign gold and they want 500 dollars a gallon for it. I haven't shopped for paint much but that seems kind of excessive so I am just curious to know where people in this region are sourcing paint for keeping colors as stock as possible.
Old Jun 20, 2021 | 06:03 PM
try these folks - https://www.automotivetouchup.com/to...87/all-models/
Old Jun 20, 2021 | 06:05 PM
Sardonicus's Avatar
That is the one place I was able to find it so far, they're about 500 a gallon though and that price just seems kinda steep.
Old Jun 20, 2021 | 06:08 PM
Sardonicus's Avatar
https://tcpglobal.com/products/rsp-a...BoCFtAQAvD_BwE
I may settle for something about like this instead when it comes time to paint it, unless I find a better option.
Old Jul 2, 2023 | 03:00 PM
Tha Driver's Avatar
You don't want to buy cheap paint unless you're going to sell the car & don't mind screwing over the buyer. DO NOT put acrylic enamel on your car. Use a base/clear urethane or if it's a solid non-metallic color single stage urethane is fine. A cheap paintjob will DEVALUE the car $500 to $1,000, because it will add that much labor to the job when it's time to do it right.
I typically spend $1800 to $2500 on primer & paint alone for the cars I paint. Only cheap GOOD paint I've found is Dupont Nason - it holds up pretty well.
Look for your local autobody supply & they will be able to mix the correct color using the paint code on your car. The best paint is Sikkens or PPG.
HTH,
Pale340
Dec 16, 2015 09:18 AM
GrahamPhotog
General Tech Help
Sep 6, 2014 01:02 AM
walkman1
Aug 30, 2013 12:18 PM
tmny277
Aug 5, 2012 09:53 AM
Wild Bill
Aug 15, 2011 02:50 PM
