US Mid Atlantic MD VA DC DE WV
Virginia XK8/Aston lumper
Old Apr 14, 2012 | 03:11 PM
  #41
enderle's Avatar
Default Dieing to see how this turns out
Looking forward to the final pics!
Old Apr 15, 2012 | 09:44 PM
  #42
deelli's Avatar
Default Jaguar XK8 front end parts
Saw your project and the cutting you're doing...wondered if you still have the pieces you cut out of the front end, specifically the drivers side headlight area and the front upper bumper cover support.
Dwight
Old Apr 20, 2012 | 01:36 PM
  #43
deelli's Avatar
Default XK8 front bumper support
Hey
Would really be interested in the front bumper support (picture attached), looks like you've removed it for your kit install.
Dwight
757 818-3878
Attached Thumbnails Virginia  XK8/Aston lumper-dsc_8225.jpg
Old Apr 21, 2012 | 06:52 PM
  #44
Ronnieb883's Avatar
Dwight, I think I still have it.. Tried to text and call you. No luck. Call or text me.. Ronnie
Old Apr 22, 2012 | 01:14 PM
  #45
Ronnieb883's Avatar
Default Rear seat had to go....
Fabric on the rear shelf was faded, couple of tears on the shelf and seats. SEAT DELETE! Not like anybody over 4 years old could fit back there anyway..:P
Old May 2, 2012 | 04:23 PM
  #46
Green01xkr's Avatar
Still waiting man... pics??
Old May 4, 2012 | 06:44 AM
  #47
Ronnieb883's Avatar
I am slow, I know.. Got the tires mounted yesterday. They look good but the shop didnt have any sticky weights to balance them. Goobers.... Been working on the seat delete. Ill post some pics later..R
Old May 6, 2012 | 08:57 PM
  #48
Spyhunter2k's Avatar
Just found this thread. I almost pulled the trigger on an Ash Mart kit a year ago but decided to get an XJ-S coupe instead.
Looking forward to your progress.
Seth
Old May 8, 2012 | 07:05 AM
  #49
Ronnieb883's Avatar
Hey, Seth. I'm still glad I got the kit. It has it's challenges but I'm up to it.... Been cleaning and derusting the rotors n calipers..
Old May 11, 2012 | 07:18 AM
  #50
Ronnieb883's Avatar
Default Wheels...
The wheels turned out great! I was wondering how the sidewalls would turn out with putting those tires on super-stretch rims.
Old Jul 1, 2012 | 01:37 PM
  #51
Ronnieb883's Avatar
Default Always something....
Hey, all. Got the wheels mounted on the car finally. So, here's my new dilemna and the picture tells all. There's a difference in the Vanquish/XK8 wheelbase by 3 or 4 inches and I guess it's becomes very apparent in the rear wheel well. I also included a collage pic of some other kits pics but their wheel well issue isn't nearly as apparent as mine.. I guess I'll have to just shift the wheel well forward. Very tempted to yank the Independent rear and go solid axle as I looked underneath and don't see any way of moving the IRS rearward and don't want to undertake lengthening the driveshaft..
Old Jul 1, 2012 | 01:40 PM
  #52
Ronnieb883's Avatar
Default Out of the garage....
Old Jul 1, 2012 | 02:48 PM
  #53
Ronnieb883's Avatar
Default ...
I've started on filling in the trunk area, fiberglass so far.. You can see I've been taping lines around the rear window and back glass. I'm gonna try to modify that area to look more like the Vanquish...
Old Jul 2, 2012 | 04:17 AM
  #54
The door looks tighter though.
Agree, you have some work to do on the wheel arches.
Too much at the rear of the wheel and not enough at the front.
And if you make it bigger overall, your wheel will look lost.
Old Jul 2, 2012 | 10:57 AM
  #55
enderle's Avatar
Looks to me like the body is all out of register, both front and rear wheels are too far forward. No wonder the kit was on sale.
Old Jul 3, 2012 | 09:10 AM
  #56
Strange. Have you sent pics to the manufacturer of the kit and asked him to weigh in? Either it's not fit correctly and needs to be shifted forward or it's fit correctly and others have likely complained as well. If so, I'm sure that some "standard" or suggested fix is known.
If I was there I'd be glad to help out, since I'm interested in knowing how big a headache this kit is. Still considering one myself.
Old Jul 3, 2012 | 11:33 AM
  #57
enderle's Avatar
It hits me that if you can find someone good with fiberglass they could reform the arches properly moving them forward, likely far cheaper (particulalry before paint) then trying to move the axle. And you could fix the front. Not trivial though by any means but it could be done. Fiberglass is used to modify wheelwells but the issue typically is that it doesn't work that well long term with a metal body (faster and cheaper though) on a fiberglass body it is likely the ideal solution. But you'd want someone who isn't learning on your car.
Old Aug 16, 2012 | 08:22 AM
  #58
RJ'sxk8's Avatar
I too am wanting to build this kit. Looking forward to updates!
Old Aug 17, 2012 | 08:07 AM
  #59
Any updates?
Old Aug 18, 2012 | 05:34 PM
  #60
Ronnieb883's Avatar
Default Updates...
Hey. Thanks for the interest RJ. I've been working on moving the rear end back some to fix the tire/wheel well issue. The IRS has about 1.5" of room and the driveshaft extends out that far... Alot of work but it'll have to do until I pull the rear eventually.
Lights. I bought some Gatling gun shrouds and projector lights. Probably get these amber halo lights and use them a parking lights.
