US Northeast ME, NH, VT, MA, RI, CT, NJ, NY, PA
I need help top is leaking fluid is there any members familiar with this crap.
Old Jun 27, 2011 | 07:49 AM
neno1127's Avatar
Default I need help top is leaking fluid is there any members familiar with this crap.
i am in rochester ny i need a jaguar mechanic this dealer here has the worst schedule i need my top fixed it wont go down and leaks green fluid please some one help me:icon_do h:
Old Jun 27, 2011 | 08:56 AM
Neno,
Go and check out the XK section, you'll find loads of information, or try a search fro green shower.
Old Oct 23, 2011 | 09:20 PM
Pdg-Jagman's Avatar
Mine did the same thing and I had to change the two lines that open and close the top.
Old Oct 23, 2011 | 09:54 PM
BlackX300VDP's Avatar
Too bad you're up in Rochester. I've done more of them than i can count. You need to replace the top hoses for the header latch. They run from the right rear trunk across the floor, under the drivers seat, up the a-pillar and to the latch. Jag did try a repair kit for them but that caused a new leak. Just need to find someone to replace the hoses. It usually takes me about a day to do them and I recommend replacing the drivers treadplate insert as well. My all cash repairs are $950. That includes hoses, insert, oil, and vacuuming and light cleaning of the interior from the oil. I hope you can find someone good to take care of it for you! Good luck.
JakeXKE
E type ( XK-E )
Jul 6, 2021 06:49 PM
sogood
Sep 15, 2015 07:35 AM
arnoldmilk
Sep 3, 2015 07:42 PM
OkieTim
Sep 2, 2015 12:48 PM
