US Western AK, CA, NV, OR, UT, HI, WA, ID
Napa in Spring
Old Mar 30, 2013 | 10:37 PM
  #81
captmal777's Avatar
Hi, Count Mal and gen In with the main group, had made resv. with davec, but just red he has joined you folks...I will presume he will cancel our 12.15 resv. ..Wow, hope this does It..Thanks Again..CM
Old Mar 30, 2013 | 10:40 PM
  #82
captmal777's Avatar
Hi Dave, I see you just signed with the group, me also. however I think It may be a good move to retain the resv. you made for 12.15pm....till the last minute...Just in case ?? Mal
Old Mar 30, 2013 | 11:43 PM
  #83
WaterDragon's Avatar
So are we now at 12?
Old Mar 30, 2013 | 11:51 PM
  #84
rocam81's Avatar
Default Two more for Redd wood
Count two more for the Grand Lunch.
Ty in advance
Old Mar 31, 2013 | 01:08 PM
  #85
Freebee to anyone who wants a set of lowering springs from a 2004 XKR
front and rear springs
These are hand me downs from Enderle and they do not fit on XJRs
If anyone wants them I will bring them for free
Old Mar 31, 2013 | 05:05 PM
  #86
DaveC's Avatar
I'm in for that if they will fit a 99 XK8!! Onward and upward.
Old Mar 31, 2013 | 05:19 PM
  #87
You are welcome to research it and try them if you think they do fit
Old Mar 31, 2013 | 07:44 PM
  #88
I am now being told we will have to all order a set menu that we can decide.
More details coming soon. I am to hear from the manager tomorrow (Monday) what we can choose from.
We will be getting a room that can accomodate 20 people.
Jeff
Old Mar 31, 2013 | 11:16 PM
  #89
DaveC's Avatar
You are doing a great job on the lunch plans. I appreciate your assistance. Are you sure you don't what to join the run up?
Can you give me any details on the spring specifications so I can research.
Thanks,
Dave
Old Apr 1, 2013 | 10:34 AM
  #90
Thanks,
Dave
Hi Dave,
Rob tells me the blue front springs are from Mina and the rear Orange ones are HKS. You can call Mina and see if your year and his (2004-2006?) can swap.
All I know is they do not fit the XJ series.
I wish I could meet up sooner, but have other commitments Sat morning. I expect to have more free time this summer. I will still meet everyone for lunch.
Old Apr 1, 2013 | 11:15 AM
  #91
enderle's Avatar
Default springs
Originally Posted by WaterDragon
Hi Dave,
Both Mina and HKS list them for the entire series so they should work on your car. I had an noise issue in the front and thought it was because the Mina springs weren't stiff enough, turned out that someone had installed the wheel well liner wrong (previous owner), became an issue with the wider front tires. That's why the mixed set. The springs from the two vendors are actually pretty similar but they are stiffer than stock..
Old Apr 1, 2013 | 02:05 PM
  #92
DaveC's Avatar
Rob,
I apprecieate the offer on the springs. I will give me a good weekend project. I assume the lowering height is about the same for the front and rear, yes? Again thanks.
Dave
Old Apr 1, 2013 | 05:23 PM
  #93
OK, slight change in reservations.
I was just told by Redd Wood, that if we reserved as I did prior, the cost would be a whopping $55 per person with less choice...
SOoooooooooo...
Now I have changed Dave C's 12:15 reservation from 4 to 8 people
and we also have a reservation for an additional 6 under Joyce Tang at 12:30
So to sum up:
8 person reservation at 12:15 under Dave C
6 person reservation at 12:30 under Joyce Tang
this gives us a total of 14 reserved seats
And we can order whatever we want this way.
Old Apr 1, 2013 | 06:19 PM
  #94
DaveC's Avatar
Well done. If there are more people we/they can wing it.
Thanks,
Dave
Old Apr 2, 2013 | 08:00 AM
  #95
captmal777's Avatar
Mr. W/D..WOW , what a great job, and what patience, This place must be really good..Thanks for all your efforts.. CM
Old Apr 2, 2013 | 10:46 AM
  #96
enderle's Avatar
Rob,
Dave
Actually they will likely lower the rear more than the front if your car was configured like most that came into the states. For some screwy reason our cars are configured with the rear higher than the front giving them kind of a jacked up look. Once installed the springs will level the car so it flat likely it always likely should have been. Be aware that you're camber will be way off after this is done and you'll need to make sure you have the adjustable bolts in the front and will need to get shims for the back to bring the camber back in line. My tire and wheel shop fixed the front of my car and I ordered shims out of Paragon in England once I knew how much my camber was off and that sorted it. The Shims go between the half shafts and the differential and can be done without dropping the rear end. It took the wheel and tire shop about an hour to dial in the camber in front and install the shims so it wasn't a very difficult job.
Old Apr 2, 2013 | 11:48 AM
  #97
Thanks for the thanks.
Just trying to get it right...
Old Apr 2, 2013 | 12:18 PM
  #98
DaveC's Avatar
Rob,
You make it sound so easy. So the install is not the issue, just getting everything sorted out after. Will I run into needing new bushings, etc.?
Dave
Old Apr 4, 2013 | 12:19 PM
  #99
Nardoswiss's Avatar
So, what's the plan? When and where do we meet?
Old Apr 4, 2013 | 02:03 PM
  #100
DaveC's Avatar
Default Here's the Plan
All,
The plan is to meet in the south parking lot of Solano Community College (4000 Suisun Valley Rd.) between 9:00 to 9:30AM on Saturday, April 6th.
We will head out no later than 9:45 and head straight north on Suisun Valley/Wooden Valley Road to Monticello Rd./CA-121. This is a true Jaguar route with lots of curves and hills.
We then go north on Silverado Trail to a winery in St. Helena. After the first stop we head south to Yountville for lunch. We have reservation at Redd Wood (let WaterDragon know you are coming).
After lunch I have a great spot for a photo op and perhaps another winery after that.
I will have maps and directions for the exact route when we meet up on April 6th.
Please let me know if you are bringing anyone as a co-pilot I will be able to get a better count.
See you all in a couple of days.
