Wheels / Tires, Suspension & handling Wheels and Tires. Discuss sizes, fitments, offsets, profiles etc etc Discuss roll bars, springs, shocks etc for your Jaguar
wheel size for Jaguar XJS???
Old Mar 26, 2010 | 04:39 AM
jetlag700's Avatar
Default wheel size for Jaguar XJS???
Hi everybody, long time no login....so here I am again.
I am buying a set of custom wheels for my 1988 Jaguar XJS and there is several different sizes that can be used on my car, but I need some help because I don't want to get wheels that are too large.
These custom wheels come in 15, 16, 17, and 18 inch.
So I was wondering if it would be okay to run 17 inch 55 series? Or should I stick to 16 inch with 60 series. There is even the option of using 18 inch with a 45 series tire but I am thinking they would be a "rough" ride. What do you guys use on your XJS that suits the car the best as well as clearance issues?
thanks guys for your help. Donna
Old Mar 28, 2010 | 07:10 PM
moto250cr's Avatar
Default XJS wheels
I have 17's on mine with 245-45's but, depending on the make of the tire, they may rub the inside of the rear quarter inner panel at the wheel lip. I trimmed mine so they wouldn't. Chris
Old May 2, 2010 | 03:20 PM
audidog's Avatar
I have seen 18"s with a 245/45/18, and 17 plenty of 17's like moto mentioned.
I'm in the same boat trying to decide what I want to go with on mine...seems like 17's offer the least hassle from what I can dig up.
I really want 18's but the wheel I am looking at does not come in an 18 in the finish I want so I will most likely stick to a 17" rim.
Old May 2, 2010 | 03:31 PM
Doug's Avatar
I've seen XJSs with 17x8 XJR wheels so at least that much is OK.
Not that anyone asked my opinion but I'd be careful about going any bigger on an XJS, even if they would fit. For some reason really big wheels just conflict with the styling of the car.
Entirely subjective, of course.
Old May 2, 2010 | 04:31 PM
audidog's Avatar
That is one of my fears too, also leading me to settle on the 17's. Wish I had one of each to test fit, but since that is not a reality I would rather go safe with the 17" wheels.
Old May 10, 2010 | 01:15 AM
jetlag700's Avatar
Default wheels?
Hi Doug , did the wheels look good on the XJS? Do you know if the offset is the same? Donna
Old May 11, 2010 | 05:02 AM
audidog's Avatar
I know I have seen a pic on a coupe but here is the only one I had, picture is Rob Wade's.
Attached Thumbnails wheel size for Jaguar XJS???-snaps_resize_819bdbba7528602d1ce49cba53f64482.jpg
Old May 11, 2010 | 08:21 AM
Doug's Avatar
Looks pretty good, IMHO. The XJR wheel is a very conservative style...and easy to clean, too :-)
IMHO, you don't want your wheels to be the sole focal point of the car. If a person looks at a car and the first thing...or only thing... they say is "Oh my GOD, look at those wheels" then you've gone to far.
Old May 12, 2010 | 04:17 AM
jetlag700's Avatar
Good advice....the XJS is too classy to competing with wheels...lol
Old May 12, 2010 | 04:18 AM
jetlag700's Avatar
thanks for posting the pic, helps me decide. I might still go for a custom wheel.
Old May 12, 2010 | 04:40 AM
audidog's Avatar
No problem, I spent Saturday looking at hundreds of pictures trying to decide on a wheel I liked... and discovering some wheels I thought I really liked looked awful once I found a picture of them on an XJ-S.
Myself I prefer a little more of a modern looking wheel, but then again my rebuild was never aimed at looking classic or all original. I settled on some 2002 XK8 wheels...but I still have my mint stock wheels if I ever want to give off the all original vibe.
G
Old May 12, 2010 | 04:58 AM
cincypix's Avatar
Default Wheel choice
I did see a red 1979 coupe with body kit and BBS RS wheels like these and it didn't look too bad.
Last edited by cincypix; May 12, 2010 at 05:00 AM. Reason: picture instead of link
Old May 13, 2010 | 03:09 AM
jetlag700's Avatar
Originally Posted by cincypix
i did see a red 1979 coupe with body kit and bbs rs wheels like these and it didn't look too bad.
niiiiiiccccee
Old May 13, 2010 | 03:10 AM
jetlag700's Avatar
G
You should check out Legend Series Champ 506 from Centerline,, they are the ones I want for my 88 XJS. They are custom made.
Old Jun 15, 2010 | 02:33 AM
samdrake12's Avatar
Banned
I have had four XK8 wheels/tyres combination fitted to my 1983 V12 xjs for last ten years or so, no real problems apart from tyre cost, the fronts may well foul the inner wing liners when on full lock, slow turns and reversing swings.I guess my old 85 XJS was the exception. It ran woderfully and it was I thought, well built. It is a cruiser, good for long trips.
Old Jul 3, 2015 | 08:36 PM
differentchances36's Avatar
Default SBC conversion XJS Wheels FItment Tires Stance Gap
Hey Guys, I have a 1983 Coupe. I purchased BMW wheels . They fit.
and they are also 19s staggered. the front are 235/35/19 (8.5)inches wide
and the rears i have not bought tires yet because i would like to know how wide i can go..they are 19x9.5
any ideas ..not opinions. Obviously this is a stance and style thing… I'm not looking for saving gas or a meaty tire.. Just want the wide fat look. but I'm unfamiliar with clearance or offsets
i believe the wheels are 05+++++
Attached Thumbnails wheel size for Jaguar XJS???-11668054_10206992843718086_1411762675_n.jpg
Old Jul 4, 2015 | 07:23 AM
moto250cr's Avatar
You just need to be careful about hitting the inner wheel lip. I had to take a Sawzall and cut about a quarter of an inch off to keep my 245 45 17s from rubbing and slicing the outside of the tires. I have also found that a more rounded off tire works better than a squared off tire.
Old Jul 4, 2015 | 07:34 AM
moto250cr's Avatar
This is mine
Chevy v8 conversion with stock springs
Old Apr 22, 2021 | 09:47 AM
Samuel Schofield's Avatar
Default Did the BMW Wheels fit?
Hi I have a 1985 JAG XJ6, did those BMW wheels work okay, bolt pattern etc.?
Old Apr 23, 2021 | 02:55 AM
Welcome to the forums Samuel,
differentchances36 was last on the forum in July 2015 - a little more than one hour after posting the question.
BrentGardner
29
Dec 16, 2024 12:13 AM
1100me
Aug 27, 2020 11:37 PM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
DrScientist
Dec 9, 2015 07:36 PM
