"LOW OUTSIDE TEMPERATURE"
Old Oct 13, 2008 | 08:22 AM
McJaguar's Avatar
Default "LOW OUTSIDE TEMPERATURE"
Does anyone know if there is a way to turn-off this warning in the message center of the console?
For any of you who may not live in a place where you've ever seen this, It seems that when the temp gets below 40 degrees of so, the message center (that usually has the mileage and fuel displays) says "LOW OUTSIDE TEMPERATURE". As if I hadn't realised this myself, or as if the display of the current exterior temp on the climate controls isn't enough.....
So when ya push the button on the end of the stalk that usually scrolls the display to the next value, the fuel mileagedisplay comes back, but only for 10 seconds.
Am I just going to have to live with this for 6 months of the year?
Old Oct 13, 2008 | 08:59 AM
Brutal's Avatar
Default RE: "LOW OUTSIDE TEMPERATURE"
no and yes, no I know of no way to turn it off, and then yes youll have to live with it.......Sorry I fix em I dont engineer em
Old Oct 13, 2008 | 09:31 AM
racerx82's Avatar
Low outside temp should not come on unless is freezing, usually 30 and below
Old Oct 13, 2008 | 10:39 AM
jvegas's Avatar
it may stay there because the temp is going from 30 to 31. at 30 it displays that message. at 31 it does not. what temp is it where you are at when this happens?
Old Oct 13, 2008 | 10:49 AM
racerx82's Avatar
Mine used to come on when it was below freezing and possible ice. Last year i think it only came on twice.
Old Oct 13, 2008 | 11:01 AM
Dennis's Avatar
ud
On mine..all I have to do is press this center RESET button once and the Low Outside Temp warning goes away till I start the car again.
Old Oct 13, 2008 | 12:01 PM
SpartanX's Avatar
You know what's worse than the Low Temp indicator? >LOW WASHER FLUID INDICATOR<
Old Oct 13, 2008 | 12:48 PM
JagXV6's Avatar
Mine comes on around 40 degrees too. I would suspect it is supposed to
be closer to freezing when it comes onto warn of possible ice on the road.
I have only seen it flash twice so far but we are getting into the colder weather
now so I am sure I will see it moreif not daily in the winter up here in Maine.
Maybe oursensor calibration has drifted off hence the warning @ 40 degrees?
Not a big deal, just another bell/whistle.
Thanks to Dennis for pointingout the "main" reset button to try. I will have to
do that when it comes on agian but so far it has not stayed on long enough.
Old Oct 13, 2008 | 02:41 PM
andersen06's Avatar
I second that!! Just hit the reset button when you start the car and its gone till the next start-up.
Old Oct 13, 2008 | 03:16 PM
McJaguar's Avatar
I'll try the tip about hitting the center 'reset' nbutton. Good one! thanks!
As for temp, it seems to go off when the indicated temp outside (as indicated on the climate control screen) says 40. But below that, it's on.
And yes, it's cold here in the mountains of Utah. I woke-up to snow on the ground yesterday. Unfortunately, my wife gets the only heated parking spot that's not currently occupied by my college-bound daughter's posessions...... [:@]
I keep telling her that her car (Jeep Commander) is a LEASE, we should take better care of the one we OWN! (The Jag) But in the end, it's more about me not wanting her to have to scrape windows or warm-up her car in the mornings.
Old Oct 13, 2008 | 03:41 PM
vaccaro81's Avatar
The indicator will come on when the temp outside hits 40 F. If you hit the main reset it will go off. But if you are driving in an area where the temp is fluctuating up and down around 40 F, as soon as the temp goes above 41 and then down to 40 again the message will come back on and have to be reset. So its not necessarily a question of hitting the reset and having the message off until you restart the car. I once asked a Jag technician about this and he told me something about resetting messages by hitting the reset and holding down the button on the end of the indicator stalk at the same time. I tried this but got no where. Maybe there is a fix but it sure is an annoying and basically useless message.
Old Oct 13, 2008 | 09:24 PM
mohrd's Avatar
OOOOOOOOOOOh! I'm excited. I hadn't tried the main reset button. I'm in Alberta and DO have to look at this indicator for about 5 months of the year. And, yes it's 40 degrees that it comes on.
Old Oct 13, 2008 | 10:29 PM
McJaguar's Avatar
Mohrd:
Having lived in Alberta myself for a very long time, I'd guess that it's more like 7 months!!!
i still have cold in my ...er...ahem.... 'extremities'.... as it were.
Old Oct 16, 2008 | 11:07 AM
The Chris X's Avatar
The mother of all idiot lights. Mine comes on at 40 and below as well. I used to hit the reset button all the time, now I just live with it. I believe it is supposed to be an indicator that there may be ice on the road. Of course if you can't figure out it's cold outside.....
The low washer fluid light is the more annoying of the two, I agree.
Old Oct 16, 2008 | 04:40 PM
racerx82's Avatar
Move to Florida. Fixes that problem. lol
Old Oct 16, 2008 | 07:54 PM
JagXV6's Avatar
But if you move to FL you won't be getting your money's worth out of all of the great Jag engineering! Not to mention my tranny and transfer case is bound to live longer cuz it stays cooler 9 months out of the year! [sm=yeahsmile.gif]
Old Oct 17, 2008 | 01:44 AM
Green Machine's Avatar
My low temp message come on at about 35 degrees and doesn't go off on it own. But this doesn't bother me because this is in the message center and there is always some message in there anyway. MPG, milage etc.
Bob N
spacemancoco
Mar 5, 2015 10:29 PM
Fosquate
Feb 18, 2012 03:31 PM
Mayor111
Dec 30, 2010 10:49 AM
Rockyf
Oct 8, 2010 09:02 PM
ruslan35
Feb 9, 2009 10:27 PM
