02 X type trip, milage computer
Old Nov 15, 2013 | 12:35 PM
louvit's Avatar
Default 02 X type trip, milage computer
ok 3 buttons by headlight switch and button on turn signal. Out of the blue all I get is the milage on the car, in Miles or klm. no AB. no gas computer no miles left to empty. where do I start?????
Old Nov 15, 2013 | 04:56 PM
clyons's Avatar
Pressing the button on the end of the turn signal stalk cycles through the various options. I've attached the relevant pages from the owner's manual.
The full manual can be found at TOPIx - TOPIx
File Type: pdf
Old Nov 16, 2013 | 06:11 AM
louvit's Avatar
yes I know, I used it all the time, I got in the car one day and the buttons no longer do anything...
Old Nov 16, 2013 | 06:27 PM
louvit's Avatar
PDF is good info, but when I press the turn signal nutton or ab nothing happens anymore, is there a fuse or switch that fails?
Old Nov 16, 2013 | 09:50 PM
clyons's Avatar
I'm no expert, but the first thing I would do is a hard reset (remove negative terminal from battery and touch it to the positive terminal for several seconds). That should cause the computers to reboot and clear any possible bad data that is causing the problem. Then see where you stand. The A/B switch won't do anything until you get into trip mode. The only switch appears to be the button in the end of the stalk.
Possible causes: Corrosion at connectors; corrosion at ground; broken switch.
Old Nov 17, 2013 | 05:09 AM
louvit's Avatar
I have never herd of touching the neg to pos battery cable, that just sounds so bad...lol...did I read that correctly? IS there a diagram of taking the stalk apart to check switch and connections?
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Raul Lara
Sep 14, 2015 07:31 PM
pnwrs2000
Sep 3, 2015 11:55 AM
dcvickers
Sep 2, 2015 06:14 PM
