02 xtype wont start help plz
Old Jul 22, 2013 | 11:25 PM
lucasgirl08's Avatar
Default 02 xtype wont start help plz
Hey all I need help and hope yall can help me. What started it off was my tail light went out ok no biggie got new bulb put back together and still no light took to place were I got the bulb and they said it could be fuse or circuit bourd. Drove it home and my husband started checking fuses under the hood. Pulled one by one and tried to start the car no go. Took a fuse tester to the fuses and they all work. Charged the battery nos start. Tryed jumping it off the starter and the starter is turning just won't start still. Has a full tank of gas when we turn the key it dnt even make that zip noise like it usually does. Lights work horn works just won't start anyone have any ideas on what it could be. And we also unhooked the battery cables to reset the computer thinking he tripped a sensor and still nothing. Help me plz
Old Jul 23, 2013 | 12:35 PM
Myjag2sexy's Avatar
Read the fuse box cover for the fuel pump and check to see if theres a fuse there. Sounds like you just misplaced it
Old Jul 28, 2013 | 04:22 PM
Thanks will check for it hope it works
Old Jul 30, 2013 | 12:51 AM
MattSteele's Avatar
Definitely sounds like the fuel pump fuse to me too. Good luck.
Old Aug 11, 2013 | 03:48 PM
Fuse is good still won't start help
Old Aug 11, 2013 | 06:12 PM
DPK's Avatar
DPK
The problem wasn't there until "Husband went in looking for a fuse"...remove husband and replace with new one...that seems to be the problem....Just saying
Seriously, he must have done something, it was running until he started to mess with the fuses..
Old Aug 18, 2013 | 03:10 PM
Exactly but I still need my car running still won't start
Old Aug 20, 2013 | 08:57 AM
daxter1987's Avatar
Follow these steps:
Get the owners manual, if you don't have it can be downloaded in the link of faqs
Go to the fuse section
Now with the list of fuses make sure every fuse is correctly in its place and has the right amperage, also push every fuse to make sure none are loose.
No sex for your husband lolz
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Jjscruggs1
Aug 2, 2017 04:40 PM
Kylejones
Sep 14, 2015 07:58 PM
Bones
Sep 8, 2015 08:34 PM
