03 x-type... bleeding brakes. Help.
Old Dec 2, 2006 | 11:31 AM
racerx82's Avatar
Default RE: 03 x-type... bleeding brakes. Help.
Should be the same..nothing new and infact, I think the subaru has the same set up. Just on the rear calipers rememebr to use the special tool and rotate the piston back into the cup....same as the subaru i think.
When bleeding the brakes losen the bleeder valve on the caliper you are working on and compress the pistion back into the cup, this will force the fluid out the bleeder valve.. Tighten the bleeder valve when your done compressing.
Do not force the fluid back through the antilock brake assembly and master cylinder!
Use dot 3 or 4 brake fluid to top off...your chose, dot 3 is the standard, and dot 4 exceeds the temp boiling point of Dot 3
Old Dec 2, 2006 | 04:05 PM
racerx82's Avatar
Ok, first off...BRAKE FLUID NEEDS TO BE CHANGED EVERY TIME YOU CHANGE YOUR PADS/ROTORS. Brake fluid absorbs heat and moister from the lines. Corrision from inside out is the #1 failure of brake lines.
Jag flushes your brake fluid out on normal service procedures every 2 years.
As for bleeding them, yeah you can have a two man process but gravity feed lines tend to bleed themselves.....
Squeezing the brake fluid through your anti lock module and up into your resevior past the ONE WAY SEALs.....yeah good advise..I hope your jag is still under warranty....This isn't your 1957 buick.
Anway, If you're not sure, get the service manual or take it to Jag. All oter info execk gave you seem to be right on the money....don't be in a rush, take your time and you'll be fine.
Old Dec 2, 2006 | 04:17 PM
racerx82's Avatar
Hey big man, when did I attack you? Anyway, sorry you took offense to it. I guess you didn't read it correctly.
Old Dec 2, 2006 | 06:39 PM
BuckMR2's Avatar
Yes Jag do it every 2 years as per maintenence sheet.
Had mine done at 60k (4 year) service at no extra cost.
Old Dec 3, 2006 | 11:57 AM
racerx82's Avatar
Well there ya go..proof in the pudding.... or something like that......some people you just can't agree to disagree... lol
I change my fluid everytime i do my brakes....(haven't done them yet on the jag though)
Old Dec 3, 2006 | 02:29 PM
racerx82's Avatar
Well I'll be a monkeys uncle. I just checked my catalog and true it doesn't say anything about not pushing it back up through the ABS module. Other makes and models (chevy, Ford, mercedes..say other wise)
I guess to each his own...Something I would never do anyway...and I don't recommend it as normal procedure.
Moisture gets into the fluid from the heat build up and cooling....also from the normal condensation from tempature variance.
Old Mar 22, 2007 | 01:26 AM
andersen06's Avatar
execk2 is way to serious Im glad he didnt last...
Old Mar 22, 2007 | 11:42 AM
bigdreams05's Avatar
+1 on the seriousness. What was up with that? Old post, but whatever! Also, he said something about the rotor not being bolted on being a bad idea. I wonder if he ever heard of something called a rim and lug nuts?
Old Mar 22, 2007 | 11:43 AM
ORIGINAL: ja00stype
Anyone got any pictures of how the rear caliper tool looks like?
I'll take pics of mine tonight when I get home and I'll post it up!
Old Mar 30, 2007 | 12:57 AM
aquill1's Avatar
Really makes you wonder if he has ever even done a brake job like he says he has!!! I have never had a rotor or disc as he states be bolted on any car I have ever done! Yeah they may be glued onto the car because of rust but rotors are not attached other than lug nuts and the back side of that good old rim!
Old Oct 12, 2008 | 03:08 PM
Thermo's Avatar
Veteran: Navy
rajinder, did you follow the guidance of opening the vent port on the caliper as you squeezed the piston back in? If you did this procedure, it is possible that you allowed a little bit of air into the system and what you are feeling is the compressing of this air bubble. If you bled the brakes too, then you didn't get all the air out.
Please keep in mind that the first time you step on the brakes, you will get the spongy feeling in the pedal as you are pushing the pistons out to rest against the pads. But, after a few initial pumps sitting still (immediately following the maintenance), the rest of the times you step on the brakes should be the normal feel.
Chris "Thermo" Coleman and K'Re Ann, the 03 X
P.S. All of the vehicle that I have worked on, I have always simply pushed the piston back into the caliper. I just don't use a lot of force pushing it back. I figured if the pressure bleeds off when you release the brakes, then that same path is still there when you do a brake job and you manually push the piston back. I've done brake jobs on Mitsubishi's, Ford's, Chevy's, and Dodges. Never a problem.
Old Oct 12, 2008 | 05:19 PM
JagXV6's Avatar
Have to agree with Chris, I have done many brake jobs on ABS equipped carsand always just gently pushed the
piston back in. I even asked a mechanic friend of mine and he said when ABS systems
first came out it was thought that the system may be damage if the fluid was pushed back
through but that turned out not to be the case. There is nothing wrong with opening the
bleeders and doing it that way either. Just be aware that if you do choose this method you
should bleed the brakes after. Something that I did not see mentioned is that it is a good
idea to start with the caliper furthest away form the master cylinder. Noteif you only did
the rear brakes you shouldonly need to bleed the rear 2 calipers.
Old Oct 12, 2008 | 05:48 PM
Dennis's Avatar
ud
I just did all four Rotors and pad sets about a year ago...what was mentioned above from Chris and V6 is good advise..
here is the proper brake bleed pattern..
Paora
Feb 4, 2021 12:36 AM
Mac Allan
Jul 20, 2020 05:46 PM
RaceDiagnostics
Apr 4, 2016 04:00 PM
sg997tt
Oct 9, 2015 10:57 PM
Johnken
Oct 2, 2015 10:12 AM
