03 X-Type Coolant Replacement
Old Oct 7, 2007 | 06:56 AM
Double Tap's Avatar
Default 03 X-Type Coolant Replacement
I live in the USA if that makes any difference as to the what the
answer is.
I have an 03 X-Type 2.5 with 11,500 miles. I got at the end of
January with 3,200 miles from a relative so I know this is the
original mileage.
I want to replace the coolant. It is light red in color so I am
guessing it is the same type as GM Dex-Cool but I do not know for
sure.
Would someone please tell me the replacement type I should use to
equal the original type and if there is any special way to drain
the system with any little gotcha that I need to worry about.
Double Tap
Old Oct 7, 2007 | 09:18 AM
Skyjump136's Avatar
Default RE: 03 X-Type Coolant Replacement
Here you go...
http://jagmotorproject.blogspot.com/...al-fluids.html
Engine Coolant: JTIS Spec: WSS M97B44 D. This is compatible with long life marketed anti-freeze. Originally developed for GM, called Dex-cool, this fluid is pink/orange in colouor, not green. Long life specifies 5 year 150,000 mi changes. I don’t agree and change mine every 12 to 24 months max. Brands: Prestone Extended life 5/150. This is a new generation (pink/orange) coolant compatible with all coolants - green, pink, orange, or whatever. Capacity: 10.6 qts 3.0L and 2.5L – but expect that you might not get the entire system drained from the heater core and engine block.
Old Oct 7, 2007 | 05:57 PM
Nice one skyjump........add to the FAQ section I think
FAQ'd n locked!
Jim
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
jehart49
Sep 12, 2015 05:36 PM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
