'04 Jag x-type 3.0 - Gear Box failure
Old Feb 17, 2019 | 09:12 PM
sharkstopper's Avatar
Default '04 Jag x-type 3.0 - Gear Box failure
Forum,
I have had intermittent gear box issues over the past year. In the past it would only happened when I was parked and the car wouldn't go forward or reverse. I don't know if this was the correct thing to do but I just restarted the car and it would fix the problem.
The other day was different, as I was driving about 30-40 mph the car suddenly wouldn't accelerate, as if i was in neutral, I luckily had enough momentum to get to the side of the road.
I shut the car off and restarted and it got me going but after 40 yards as I was driving, it happened again. I kept the car in neutral, restarted and the car worked for about a mile until I returned home.
I haven't used the car since 2 days ago when the incident occurred.
Does anyone have any ideas what the issue may be?
SharkStopper
Old Feb 18, 2019 | 07:47 AM
car5car's Avatar
Is it manual or automatic? It is usually called transmission in USA.
Write info in signature like mine.
Old Feb 18, 2019 | 11:57 AM
Default Jag "04 X-Type 3.0 6 cyl gear box failure
automatic.
Old Feb 18, 2019 | 12:24 PM
car5car's Avatar
Transmission is slipping:
worn out clutches or bands
worn out o-rings
worn out pump
low ATF level
clogged filter
old ATF
What to do:
check codes
replace ATF/filter, add stop-slip additive
check ATF pressure in all ports
maybe replace ATF twice
Old Feb 18, 2019 | 01:59 PM
Dell Gailey's Avatar
Or check the shift connection on the transmission for correct setting. Has a tendency to wear and change the ability to shift correctly.
Make sure to read the embedded solution thread, too.
https://www.jaguarforums.com/forum/x...-fault-206869/
AZ RICH
Jun 12, 2018 01:35 PM
Alfredo209
Aug 4, 2016 04:39 PM
GaryBKirk
Mar 11, 2013 10:06 PM
Rev
Jan 16, 2012 11:31 PM
GENESIS
Jan 7, 2012 08:34 AM
