05 3.0 wagon - throttle stutter
Old Apr 11, 2016 | 02:34 PM
Roger RB's Avatar
Default 05 3.0 wagon - throttle stutter
My wife's 05 (135k miles btw) has for some time been acting up. first symptom was at very slow speeds, say when you turning a corner, then step on it, it wont respond at first then jolts. later to began to also occasionally sputter again are relatively slow speeds when you accelerate slowly. this is happening more often.
We've replace the plugs, the Mass Air Flow, bot of which seemed to make a difference in performance but the symptoms are still there
The mechanic I use for my Beemer thinks it is the throttle position sensor which apparently in this model year is built into the throttle body.
Local dealer is extremely proud of this particular feat of engineering and strongly believes it is worth every penny of the $950 it wants for the part alone.
Hence this desperate plea for any help from this forum
Old Apr 11, 2016 | 10:05 PM
Lemons Racer's Avatar
Have you run any codes? If not that would be the first step, otherwise everyone is just guessing.
Old Apr 12, 2016 | 09:37 AM
clyons's Avatar
Have you checked to see if the throttle plate needs cleaning? If dirty it could be sticking. See this thread: https://www.jaguarforums.com/forum/x...roblems-99032/
Old Apr 14, 2016 | 01:49 AM
jaggedy's Avatar
I don't know your situation at all, but I have seen threads on cleaning and repairing the TPS. I also know that you can find them used including the throttle body cheap on eBay. They are really easy to install.
My car used to have a rough downshift that was noticeable when I would brake to make a turn and then accelerate again. It would take a moment to downshift before I could accelerate properly. Transmission fluid and some solenoids helped. That is likely not your issue though.
Old Apr 14, 2016 | 01:56 AM
jaggedy's Avatar
Brand new for $279 including shipping and warranty:
New Genuine Jaguar Throttle Body XR845053 s Type 3 0 x Type 3 0 XJ 3 0 V6 | eBay
Used also available for about $25.
05 06 07 08 x Type x Type 3 0 Throttle Body Nice Used | eBay
These links are from my phone's mobile eBay, so I hope they work for you.
Good luck!
34by151
May 6, 2024 12:20 PM
Andi Allko
Apr 4, 2016 04:06 PM
Travis O'Gallagher
Apr 3, 2016 02:49 PM
agentorange
Mar 27, 2016 05:08 AM
