2001 touch screen
Old Jul 28, 2015 | 10:23 AM
derbysatellite's Avatar
Default 2001 touch screen
Hi,
thanks for reading.....
Problem with my touch screen, phone button on left of screen doesn't appear to work?
I've tried to enter the secret menu holding "Phone and Menu" doesn't enter menu and also tried nav,up,nav,up,nav,audio,audio,audio. (tried both temp up and fan up)
Any ideas ???
Old Jul 28, 2015 | 10:43 AM
Alfadude's Avatar
Welcome to the forums, Derby. Lots of friendly helpful people and a lot of good information here. One thing that is asked of new members is to stop by the new member area and introduce yourself. When you have a moment check that out.
As for your situation you do not say if you have had the car a long time and the phone button worked and all of a sudden it quit working or if the car is new to you and you hit the button and nothing happened? I am guessing it is the latter and that you do not have the phone module installed, which was an option or something that could be installed by the dealer. Not many of the cars came with it, although they all had the button.
Old Jul 28, 2015 | 10:52 AM
Hi, will do...
And yes does have a phone in the arm rest, and the handset does work.
Old Jul 30, 2015 | 09:28 AM
Is they a way i could prob short the button out to see if its that that is failing???
Old Jul 30, 2015 | 12:34 PM
Alfadude's Avatar
Can't say that I can help you as I am not familiar with that arrangement that actually has a factory handset in the car. It sounds like the "button" you are talking about is on the touch screen display and not a mechanical button? If so, is that same area that is pushed for the phone also used for something else on another page? If it is, does that function work on another page? If it would work, then it is not the touch screen itself.
If that area on the touch screen look like it is kind of worn from a lot of use? Those units are resistive touch screens and there is a very fine layer of a metal on the inside of that film layer you press called Indium Tin Oxide. The ITO on the inside of the touch screen could be cracked from constant activation over the years or the kind of activation it has seen (Pressed on an angle with fingernail or keys or something else). What you could try is try pushing with more pressure than you typically would. What that will do if the ITO is cracked is allow more electrical contact area and less resistance, which would possibly allow that button to work. If you could get it to work that way then chances are the ITO on the touch screen is cracked and failing and you would have to replace it at some point. I sell touch screens for a living, but other than that I'm sorry, I can't be of much help. Maybe someone else will chime in.
Old Jul 30, 2015 | 05:17 PM
sorry i do mean the mechanical button.
Old Jul 31, 2015 | 11:16 AM
am looking for the wiring schematic to try and test myself.
also needing it to try and sort my sensor fault out.
searched this forum and google no look so far
Old Jul 31, 2015 | 12:48 PM
clyons's Avatar
Gus's site has the wiring guide.
JagRepair.com - Jaguar Repair Information Resource
Old Jul 31, 2015 | 02:24 PM
Originally Posted by clyons
Many thanks for this
Poet
Feb 7, 2025 02:18 PM
ryan_border
Dec 23, 2015 04:27 PM
Poet
Oct 2, 2015 09:00 AM
aadjei
Sep 25, 2015 03:07 PM
zdrapec
Sep 25, 2015 05:49 AM
