2002 2.5 auto cranks but won't start
Old Mar 8, 2013 | 08:21 AM
Alfadude's Avatar
Have you been tried getting a jump to get it started? If so, did that work? Or maybe get the battery charged and try it?
Old Mar 8, 2013 | 04:14 PM
Corycarlo's Avatar
I put the charger on it and tried to start it with no luck. Going to pop up the back seat and check the voltage at the fuel pump wiring harness next. When I turn the key on I hear a very faint sound, really don't hear the fuel pump kicking on so I'm sure it's probably bad. Do the fuel pump relays ever go bad? Also is there a fuel pump fuse? Thanks
Old Mar 9, 2013 | 04:19 AM
steveinfrance's Avatar
There is a module under the rear seat that appears to drive the pump directly, not via a relay.
I don't know this model but on XK's the pump is pulse width modulated to set pressure at the fuel rail so a relay won't work. Maybe the same here.
I'm afraid it is your pump but 0V at the pump harness would be good news.
Old Mar 19, 2013 | 03:13 PM
Corycarlo's Avatar
I got voltage at the pump harness so its defiantly the fuel pump. Now my next question is 100% real, has anyone cut an access square under the seat to change the fuel pump? I could then tack weld an inch on top of the square all the way around and gasket it back down. Even tack it down in a few spots but then I have an access hole for future pumps and don't have to drop any major time or money in having a garage do it. With an access hole it would be an hour job at the max. Ok, let's hear the comments on this.ha
Old Mar 19, 2013 | 08:47 PM
Corycarlo's Avatar
Fuel pump access panel ideas anyone? If no one is crazy enough to give me ideas I may have to do it the old fashion way
Old Mar 20, 2013 | 04:03 PM
Corycarlo's Avatar
Bump
Old Mar 21, 2013 | 03:22 PM
Corycarlo's Avatar
Ttt
Old Mar 22, 2013 | 04:48 PM
  #28
Alfadude's Avatar
I recall a discussion on here a while back where someone wanted to do the same thing as you. I can't remember if they followed through though. As I recall there was debate how wise that would be with cutting/welding so close to the tank. If you do a search I'm sure you can find that thread. Personally, if I was faced with the same issue I would just bite the bullet and get the tank removed. Yeah, a pain in the **** and not cheap, especially if you have it done by a shop, but chances are you would only do it once. Not like something like that is going to be replaced every year. If it would need to be done again it might be ready for the boneyard by then.
Old Mar 23, 2013 | 10:10 AM
Keith X's Avatar
I did it...fuel pump shorts out in fuel tank!!
The easy way in is to cut the hole larger.
I did it with metal sheet siccors and cut a 'flap' out so i could remove the fuelpump.
After refitting the new fuelpump i replaced the metal and ducktaped the hole...whats the problem? Its under your backseat...or you remove the complete fueltank, your call.
However..before you start cutting be shure its the pump and not some jammed filter.
May the force be with you
Old Mar 23, 2013 | 04:45 PM
  #30
Corycarlo's Avatar
Thanks guys! Going to change the fuel filter then if (when) that doesn't work I'm cutting the flap! Thanks guys!
Old Mar 23, 2013 | 09:18 PM
  #31
Corycarlo's Avatar
The floor is cut. Called it a night and will swap out the fuel pump tomorrow. Will update
Old Mar 24, 2013 | 04:22 PM
  #32
Corycarlo's Avatar
Cut a hole and changed the pump. Purrs like a kitten now! Thanks everyone
Old Mar 31, 2013 | 02:02 PM
  #33
DragonKat's Avatar
Make sure to check the Inertia Switch switch first! i just took the whole top end off the engine before reading this post and it turns out i just trip the Inertia Switch when i let the jack down to fast from rotating tires.
Old Apr 1, 2013 | 05:18 AM
  #34
Corycarlo's Avatar
That was one of my first things I checked hoping it was an easy fix. Mine was the fuel pump. Hut good advice for others!
Old Jul 26, 2013 | 10:28 PM
  #35
Hajiand's Avatar
So my friend and I are looking to do this exact same repair with the access cut in order to reach the fuel pump. I was wondering if you anyone had any pictures of where they made the cut and any additional advice information you think we should know before trying this repair?
Old Aug 8, 2013 | 04:41 PM
  #36
Corycarlo's Avatar
Sorry for the delay in reply but I did not take any pictures. I can only suggest not doing the repair in this fashion since looking back it was extremely dangerous. If you must cut just barely thru the metal as the tank is very close under it. Keep fire extinguisher on hand.
JarodL
Mar 7, 2024 01:39 AM
Charlene n John
Sep 28, 2015 06:01 AM
Raul Lara
Sep 14, 2015 07:31 PM
Charlene n John
Sep 6, 2015 11:03 AM
Raul Lara
Sep 2, 2015 05:23 PM
