2002 X Type 2.0L Automatic
Old Aug 10, 2014 | 06:56 AM
jagmanaz's Avatar
Default 2002 X Type 2.0L Automatic
If anyone has had these problems i would be glad of all the advise i can get......
Code 1638....can problems
Code 1603...... TCM problem
I fully charged the battery, then installed a new TCM, i removed the IC and did a pin test....ok....checked the wiring connectors as far as i could reach but the engine will not crank. The IC lights up as normal but turn the key and it just refuses to crank. I removed and cleaned the battery to chassis grounds. After which i am thinking ECM....is there a way to pintest the ECM.....Any answers will be greatfully accepted, and any other information the same.
Old Aug 12, 2014 | 08:20 AM
fourbyfourbyfar's Avatar
have you checked that the gear selector switch for park or neutral is ok as this will stop it cranking also in stickeys threads there is a jag doc which shows how to check the tcm and ecm
way2far
Aug 31, 2022 09:26 AM
Raul Lara
Sep 14, 2015 07:31 PM
David Thompson
Sep 3, 2015 07:48 PM
KarimPA
Sep 3, 2015 07:32 PM
dcvickers
Sep 2, 2015 06:14 PM
