2002 X type 3.0 Engine Noise ?? Please advise
Old Jun 18, 2014 | 02:25 PM
mccarthyj6's Avatar
Default 2002 X type 3.0 Engine Noise ?? Please advise
Hi I am new to this forum support.. Could anyone provide some advice/knowledge as to what could be making the high pitched noise in my attached youtube recording? It gets worse when I rev the accelerator. My oil light blinked a few times before I pulled over and received a tow home. Oil level was low I believe I might have a lower leak maybe at the pan. I felt vibration coming from the back cam so now I have the covers off now; however all looks aligned.. Any support/opinions are greatly appreciated!
Old Jun 19, 2014 | 07:03 AM
car5car's Avatar
Remove drive belt and use stethoscope.
If oil is low, connecting rod bearings go bad.
Most likely #6
Old Jun 20, 2014 | 07:02 AM
DKurtti's Avatar
Where's your oil cap?? Sounds like a sucking whistle with a background tick to me. But my laptop speakers are (insert farting noises here). You've got a huge vacuum leak with that oil cap off. Is there a change in sound with the cap on?
Old Jun 22, 2014 | 01:28 PM
mccarthyj6's Avatar
Thanks Car5Car, when you say engine belt are you referring to the Serpentine or the timing chain? Also what am I using the stethoscope to listen for?
I was thinking I ruined an engine end bearing.. the noise is coming for the rear of the engine. I have the rear cam cover off but cant seem to figure removing the timing chain to get to these end bearings.. Am I in the right area?
Old Oct 4, 2014 | 05:15 PM
jesusoro1's Avatar
Question engine noise
Horrible siren like engine noise seems coming from the area where serpentine belt is. I replaced the serpentine belt, pulli and wheels "all new" and the noise persist. The noise increases and decreases with acceleration. (even when in park)
I just don't know where to look.
Someone please help with this enigma.
Thanks .
Jesus Oro1@comcast.net
Old Oct 4, 2014 | 09:00 PM
wa3ra's Avatar
I've listed a few times, sounds like top end, hung valve or lifter, possibly?
h4wk
Nov 27, 2015 05:10 PM
montypeek
Sep 6, 2015 04:57 PM
EastFalk
Aug 29, 2015 08:22 PM
roumor
Aug 28, 2015 01:02 PM
sorken88
Aug 28, 2015 04:09 AM
