2002 X type 3.0 Engine Noise ?? Please advise
Hi I am new to this forum support.. Could anyone provide some advice/knowledge as to what could be making the high pitched noise in my attached youtube recording? It gets worse when I rev the accelerator. My oil light blinked a few times before I pulled over and received a tow home. Oil level was low I believe I might have a lower leak maybe at the pan. I felt vibration coming from the back cam so now I have the covers off now; however all looks aligned.. Any support/opinions are greatly appreciated!
Where's your oil cap?? Sounds like a sucking whistle with a background tick to me. But my laptop speakers are (insert farting noises here). You've got a huge vacuum leak with that oil cap off. Is there a change in sound with the cap on?
Thanks Car5Car, when you say engine belt are you referring to the Serpentine or the timing chain? Also what am I using the stethoscope to listen for?
I was thinking I ruined an engine end bearing.. the noise is coming for the rear of the engine. I have the rear cam cover off but cant seem to figure removing the timing chain to get to these end bearings.. Am I in the right area?
Horrible siren like engine noise seems coming from the area where serpentine belt is. I replaced the serpentine belt, pulli and wheels "all new" and the noise persist. The noise increases and decreases with acceleration. (even when in park)
I just don't know where to look.
Someone please help with this enigma.
Thanks .
Jesus Oro1@comcast.net
Thanks .
sorken88
Aug 28, 2015 04:09 AM
