2002 x type headlight, side marker light issue
Old Sep 27, 2014 | 09:34 AM
bernardfamily1015's Avatar
Default 2002 x type headlight, side marker light issue
passenger low beam and passenger front side marker don't work normally. however when i use the key fob to lock/unlock doors, both lights flash.
any ideas?
Old Sep 27, 2014 | 09:54 AM
Thermo's Avatar
Veteran: Navy
Bernard, first off, welcome to the Forums. Lots of good information and people here willing to help you get past your problems. But, we do ask a small favor of you. Please stop by the New Member section and tell us a little bit about yourself and your car. We pride ourselves in being a better car group and as part of this, we like to get to know one another and keep things on a more friendly basis than you will find elsewhere. This will also give you a chance to meet those that make this place what it is.
As for your problem, I guess I am a little confused as to what you are seeing. When you say Low beam, are you referring to the yellow light in the passenger low beam housing or the actual white head light? I know in my car, the headlights do not flash when you press the lock button twice. I only get the yellow turn signals to flash to acknowledge the car is verified locked.
If the turn signals are not activating on the one side, I have to ask whether the rear turn signal on that side works too? I ask this as if this is only a turn signal issue, we are down to 2 possible components. If the rear turn signal is not working on that side too, then your problem is the turn signal stalk on the steering column. If the turn signal works on the rear of the car, then your problem is a bad GEM module and you will need a new module.
Please let me know what your responses are. I will help you get to the bottom of things. How are you with using a multimeter? Just trying to figure out what sort of tests that we might be able to do should we need to go that way.
On a side note, if you are near the DC area, we are having a "Pride of Jaguars" meeting tommorrow (9/28) up in Fairfax, VA at the Fair Lakes shopping center. We will be meeting from 8-10 am and then most of us will be following that up with a brunch at The Blue Iguana (nice restaurant). I will be there and I can then see things first hand and we can take things from there. I live in Southern Maryland. So, if you don't mind a litlte bit of a drive and are in the Richmond/DC area, it wouldn't be that far of a drive. Look up "California, MD" (yes, it is a real town).
Old Sep 27, 2014 | 11:55 AM
1989xjs's Avatar
Chris, I was wondering if you've worked on the xjs before? I found one that I'm considering to buy but it needs some TLC. I'm thinking that new plus, filters, and new gas will get it running well. Is this something you could help me with if I buy it? I can tell from your posts that your experienced working with Jaguars.
I'm also in Maryland. Sorry for replying on this post but I couldn't figure out how to private message you.
Old Sep 27, 2014 | 02:01 PM
Thermo's Avatar
Veteran: Navy
1989xjs, I am not familiar with the XJS per se. But, I know enough about Jags that I am sure we can get you taken care of. What part of MD are you in? I am in the southern tip near California/Hollywood (hour south of DC).
Old Sep 28, 2014 | 01:18 PM
1989xjs's Avatar
Chris, thanks for your reply. I'm in Baltimore. Maybe we can talk? If possible, send me your phone number by private message. I think you can send it to me as a visitor message. Thanks.
Old Sep 28, 2014 | 01:36 PM
Thermo's Avatar
Veteran: Navy
1989XJS, get a few more posts out there and then I can PM you with my phone number. The magic number is 10 posts. Once you get that, a lot will open up to you.
Old Mar 11, 2015 | 05:44 AM
JagKat's Avatar
New Member... I see that the key is ten posts. Thanks for info!
h4wk
Nov 27, 2015 05:10 PM
Jimscriv
Nov 4, 2015 02:18 PM
montypeek
Sep 6, 2015 04:57 PM
roumor
Aug 28, 2015 01:02 PM
divingmom
Aug 25, 2015 07:54 PM
