2002 X Type RH Rear Door Latch Removal
Old Jun 17, 2013 | 12:35 PM
GGGray's Avatar
Default 2002 X Type RH Rear Door Latch Removal
Hi Folks
Trying to replace the door latch on the RH passenger side of my X Type. I'm struggling to remove the plastic cover that secures the clip on the door latch rod. A very good previous thread says it slides off sideways if you push in a bit of plastic. Can anyone give more detail? I can't find the bit of plastic you push in.
Any advice gladly received.
Regards
Old Jun 20, 2013 | 06:54 PM
Jagman68's Avatar
Hello
Not sure if you have done this now but when I replaced my door lock I had to remove the small window above it to gain access, its a bit time consuming but you will need to take it slow to make sure nothing else gets damaged. Hope this helps, good luck
Old Jun 21, 2013 | 11:02 AM
GGGray's Avatar
Default Thanks
Thanks for your advice Jagman68. I resorted to brute force and ignorance in the end but this seemed to work.
stanjag
Dec 29, 2024 08:26 PM
h4wk
Nov 27, 2015 05:10 PM
montypeek
Sep 6, 2015 04:57 PM
Spikepaga
Aug 30, 2015 12:59 PM
jagent
Aug 30, 2015 08:42 AM
