2002 X-Type WITH A WINDOW PROBLEM
Old Oct 10, 2019 | 05:13 PM
hak's Avatar
hak
Default 2002 X-Type WITH A WINDOW PROBLEM
2002 X-Type with 98,000 miles auto trans. The passenger side window will not go all the way up. The window stops about ˝ inch from top position. I tried resetting the memory for bottom and top positions without any improvement. Later my wife tills me that our granddaughter was sticking her hand in the window when it was going up so she could watch it stop…my granddaughter did this several times. Could this have caused the problem with the window not going all the way up. Also I push the up button and then I grab the window and help it the window will close completely.
Is there a way to reset the window object sensing?
Any ideas on the cause of the problem and or a solution would be greatly appreciated.
Thank you
Howard
Old Oct 10, 2019 | 06:02 PM
Dell Gailey's Avatar
I'd try a hard battery reset. Disconnect negative battery cable, touch (with metal jumper) to connected positive cable. Reconnect negative cable. Then try window and teset.
Old Oct 13, 2019 | 10:46 AM
hak's Avatar
hak
Your recommendation worked. Thanks for your help.
Howard
02silver_x-type
Dec 22, 2014 07:45 PM
JCam
Sep 22, 2014 08:37 PM
monz87
Sep 8, 2010 05:34 AM
