Old Aug 18, 2014 | 11:05 AM
bachour's Avatar
Default 2003
abs light is on ,what could be the problem
Old Aug 18, 2014 | 12:38 PM
Paulc732's Avatar
bachour.
Could you have the codes read usually autozone will read them for free and post the codes here.
there is a lot that can go wrong to put on the light the codes will help us narrow them down.
Old Aug 18, 2014 | 02:06 PM
Five Speed's Avatar
Hello & welcome . Could be !! ABS unit ( Under bonnet /Hood ) Reluctor /Speed rings on any of the 4 wheels , ABS sensors ,brake ib ABS sensor cable etc , etc . As Paul said , get the codes read & diagnose the fault . I doubt its the ABDS unit & anything else should be a reasonably easy fix. Also Jag X type parts are not to expensive .
Old Aug 18, 2014 | 05:18 PM
JDBarrister's Avatar
Mine was the ABS unit. It is not cheap to fix, but replacing it solved my intermittent ABS problem.
Old Aug 18, 2014 | 08:16 PM
Thermo's Avatar
Veteran: Navy
bachour, get the codes read. With the information that you provided, it could be way too many things. Hope that it is one of the following codes: C1145, C1155, C1165, or C1175. This would be one of the speed sensors and that is normally a pretty easy and cheap fix. I am placing money that it is more than likely either C1165 or C1175.
Old Aug 20, 2014 | 10:34 AM
bachour's Avatar
Default Thank u
Thank u
Old Aug 25, 2014 | 10:29 AM
bachour's Avatar
Default abs unit
how much u think the unit cost be around?
Old Aug 25, 2014 | 10:48 AM
bachour's Avatar
hi thermo;i did get codes (c1145,c1155,c1165,c1175) replaced the right rear sencor actually half the cv shaft,but the abs light still on which causing the engine lit to stay on as well,im wondering what coud be next,this is pain in the butt
Old Aug 25, 2014 | 11:43 AM
Tennscott's Avatar
I would send your unit off for repair. Check ebay for repair service, I think I paid $125. I think there would be less rick then buying a used unit.
Old Aug 25, 2014 | 12:08 PM
Thermo's Avatar
Veteran: Navy
bachour, based on you getting all 4 codes, that would lead me to believe that you have a problem with your ABS unit or the plug for the unit is not seated properly and it is not making proper connections. Let me get home and look at the diagrams and lets see what we can find from there. It may be something as simple as the fuse to the ABS computer/module is blown. Hard to say what you may find.
Old Aug 25, 2014 | 12:43 PM
Tennscott's Avatar
Also, check the ground wire. It is located just behind the left headlight. There is two located in the same place. I would check both grounds.
Old Aug 25, 2014 | 01:02 PM
flyrr100's Avatar
My ABS light was on. My Jag guy sourced me a rebuilt ABS pump for $300.
Old Aug 25, 2014 | 04:14 PM
Thermo's Avatar
Veteran: Navy
bachour, check fuse F3 in the engine bay fuse box (60 amp fuse) and fuse F96 (7.5A fuse) in the passenger cabin fuse box. Odds are, fuse F96 is going to be the one that is blown.
Old Aug 26, 2014 | 07:25 AM
bachour's Avatar
Thermon! Thank U so much for ur help and info, I will look into it , much appreciated
Old Aug 26, 2014 | 07:27 AM
bachour's Avatar
Thank u
Old Aug 26, 2014 | 07:29 AM
bachour's Avatar
Thank u , I will check
Msteiner
May 16, 2016 12:19 AM
jospolice
Oct 2, 2015 07:16 PM
jospolice
Oct 1, 2015 07:52 AM
apolloxk8
Sep 28, 2015 08:27 PM
SoCalJagS
Sep 27, 2015 09:20 AM
