2003 Jag X-Type — keyway into ignition switch
Old Jul 24, 2018 | 02:13 PM
GoKeyJoe's Avatar
Default 2003 Jag X-Type — keyway into ignition switch
So we’ve been working on getting the ignition cylinder out of an ‘03 Jag X type... for some reason, even in the on position, the cylinder is not releasing from the house, am I not hitting the button right or something?
BIGGEST problem is when we took the ignition switch off, opposite the ignition cylinder, we started messing with the pressed aluminum keyway that turns the ignition switch over, AND BROKE THE TIP OFF... big bloody oops there. I called Jag and tried to explain, but they said the housing and the switch are all they sell... seems like this pressed aluminum piece SHOULD be removable. Any advice?
Last edited by GoKeyJoe; Jul 25, 2018 at 12:40 PM. Reason: Better definition of issue
Old Jul 24, 2018 | 05:20 PM
Welcome to the forum GoKeyJoe,
I've moved your question from General Tech Help to X-Type forum. This is the place to post technical questions about your model.
Old Jul 24, 2018 | 07:01 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...barrel-170572/
Old Jul 24, 2018 | 07:10 PM
https://www.justanswer.com/jaguar/3g...-not-turn.html
Old Jul 25, 2018 | 12:28 PM
GoKeyJoe's Avatar
thanks my friend, didn’t QUITE get me the answer, but was some good info. I have a feeling I’ll be replacing a steering column now
Poet
Apr 11, 2022 06:51 PM
prof neal
Dec 12, 2016 09:31 AM
Atlastajag1
Dec 2, 2016 10:32 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
androulakis
Jan 10, 2007 10:37 PM
