2003 X-Type will not crank!! Advise/Help please?!?
Thang, in the US, saying to someone "you're a little ignorant" is a strong personal attack. It is not used as if you felt someone "ignored" or "ignores" as much as it is used to characterize someone as having a low mental capability. In fact, it is used as if "ignorant" and "ignore" have no association.
Excuse me NCbeachbum, I don't want to be Smart A., but you're a little ignorant, when you ask for advice, Thermo tell you to check the battery and you keep say the battery is not the issue, I don't know how do you try to turn the engine, with 8 inch handle wrench? But I know as Jeeves12 said if you don't remove the spark plugs it's almost impossible to turn the engine and it not likely you did! Next time try all the advises before com to the conclusion. Forgive me for my smart A.
I once have my car could not crank, and find out the A/C compressor clutch was seized, after replace it the engine just start it right up.
I'm having the same problem. Changed the starter and the battery cables, check all the fuses and all were fine. The only thing out of place is the alarm light in the center by the shifter. It flashes repeatedly after I turn the key to II position, but I get nothing... Can any one help?
Darren Schermuly
Sep 11, 2015 07:55 PM
