2004 jaguar x type no start
Old Mar 1, 2018 | 12:01 PM
xtypemarket's Avatar
Default 2004 jaguar x type no start
hey guys,
i have a 2004 jaguar. seems to have the same problem every one is having.
it cranks but no start.
i checked gas and its good i have checked the fuse f92 i keep reading about, except on the 2004 it will be f10 on the engine fuse box as its states coil ignition. checked all the fused and it seems to be good.
yesterday i pulled the coil and there was no spark.
i am going to check the crankshaft position sensor today and see if that gets the problem fixed.
does any one have the wiring diagram to the coils and information on how to check the crankshaft position sensor?
your help is much appreciated.
Old Mar 1, 2018 | 07:11 PM
PanamaJag's Avatar
Elect Diagram for the coils circuit - MY2004.25 (Note - 21 II in the center of the diagram is the supply from Fuse F10 to the coils). Click on photo once to enlarge - click on the enlarged photo to zoom.
From Shop Manual - Ignition Coil Testing
2004.25-Coil Testing.pdf
Old Mar 2, 2018 | 02:13 PM
JagV8's Avatar
The PCM has to activate the coils and won't if:
1. it thinks bad key (PATS not happy)
2. no crank signal
I'm not sure checking the coils will help unless both those are good.
Old Mar 2, 2018 | 03:42 PM
Dell Gailey's Avatar
Hopefully, you have also checked the inertia switch just in case it's been tripped.
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
zach4577
Mar 10, 2017 04:57 PM
JagXtype04
Feb 25, 2017 05:50 AM
Adazard01
Feb 22, 2015 09:19 AM
jag steering
Jun 3, 2008 11:55 PM
