2004 x type rear caliper brake piston-how to retract
Old Dec 6, 2014 | 07:35 PM
eriklane's Avatar
Default 2004 x type rear caliper brake piston-how to retract
This was not fun, but, it's not hard once you know what to do. Remove rear tire, then remove the 2 13mm nuts holding the brake caliper, and remove that. If your piston is extended enough so that you cannot get the new pads in (likely), note the piston-it has a odd shaped hole in the center. Either find a big Torx bit, or, a bolt head that fits, and use a ratchet or drill(preferred) and spin the piston. The driver side goes counter clockwise to retract. Passenger side is clockwise. You need to open the bleeder first...It will take a bit if you do it with a ratchet...drill-it goes great.
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
EastFalk
Aug 29, 2015 08:22 PM
Aegis21
Aug 27, 2015 08:30 AM
