2004:X-type: Tires/Rims - Will these rub?!
Old Mar 24, 2011 | 08:13 PM
Loc's Avatar
Loc
Default 2004:X-type: Tires/Rims - Will these rub?!
I'm looking for some advice. I have checked out a few car tire calculators, but I'm kind of worried about making a bad purchase.
I'm currently running 205/44/16s without any issue (stock)
I'm looking at a nice rim/tire combo and I'm terrified to make a bad purchase.
Will 225/40/18s (18x7.5 rim) rub on a 2.5L 2004 x-type with stock suspension (80k miles)?
Thanks!
-Loc
Old Mar 24, 2011 | 08:15 PM
Loc's Avatar
Loc
whoops...I'm currently running 205/55/16s.
Old Mar 24, 2011 | 09:31 PM
j_bond's Avatar
should fit just fine as long as you have the correct offset.
I'm running 19" wheels with 225/40 tires and have no clearance issues with a +42 offset and my X-type is lowered.
Old Mar 25, 2011 | 07:37 AM
RudyF6's Avatar
My 2003 has that size, only rubs when turning while backing up. Outer edge of the tire rubs on the plastic fender liner. Go for it!
Old Mar 25, 2011 | 09:25 AM
exexpat's Avatar
As long as your offset on a 7.5" wheel is between 30 and 50mm and you run 225/40/18, you will be fine - even optionally with lowering springs.
Old Mar 25, 2011 | 03:29 PM
Jaggyx's Avatar
Offset is everything.
Old Mar 26, 2011 | 10:03 AM
Loc's Avatar
Loc
Thanks for the replies. Can someone explain offset to me? I sorta understand that it's the distance from the center of the tire to the bolt holes. But I don't know how to figure out what too much or too little offset is =\
Old Mar 27, 2011 | 12:13 PM
RudyF6's Avatar
Check this out - explains offset and backspacing.
Wheel Tech - Offset
Ol Blue
E type ( XK-E )
19
Aug 20, 2022 04:58 PM
iownme
Sep 25, 2015 08:44 AM
wcourt3010
Sep 23, 2015 01:06 PM
JagLove86
Sep 6, 2015 10:36 PM
