2004 xtype nav system
Old May 18, 2014 | 04:20 PM
leslie adlam's Avatar
Default 2004 xtype nav system
Hi can someone help me with my nav system it was working fine but now shows sat symbol in corner of screen and no map just car symbol tried cleaning disc reads it but wont load location on screen cheers les
Old May 21, 2014 | 02:26 AM
barry W's Avatar
Just a thought, I had similar issues with my Sat Nav...eventually pulled power plug, then Fibre optic cable and re inserted..works fine now....
You've nothing to lose!
B
Old May 27, 2014 | 01:57 AM
HI i tried disconnecting all wiring and re connected no luck contacted nav nz they said i need latest firmware update can any one help with this cheers les
Old May 27, 2014 | 05:07 AM
barry W's Avatar
Les ,
Methinks your DVD is up the spout but I'm no expert, the pickup starts to deteriorate as time goes on....i
Obviously go the cheapest route to get it fixed or replaced
If you were in the UK, I would suggest you try another DVD drive from a local member......
If you can confirm that's it's the DVD drive, I sell second hand in the UK for £90 plus postage.....
Suggest search round see if you can confirm it's the Drive, that being the case attempt top pick one up locally...EBay Nz?
B
Old May 27, 2014 | 05:19 AM
barry W's Avatar
Les,
Further thought, first things first, can you contact someone locally with Sat Nav to test their map?
Must be someone ....( he says)
B
Old May 27, 2014 | 03:20 PM
Thanks guys i am certain the dvd reader is ok as it reads and enters a new destination and shows route on screen etc just shows position of vehicle in the wrong area and no road map and all its calculations are from that position its like the sat locator is not working
cheers les
Old May 28, 2014 | 03:39 AM
barry W's Avatar
Les ,
Have you checked on the Sat Nav system that the map is on NZ. ( there should be various counties highlighted!)
If you go into the menu.....there are map options, check /make sure that NZ is the country the system is reading.
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
1LowCat
Sep 14, 2015 07:51 PM
texaspete
Sep 10, 2015 08:34 AM
Mike Green
Sep 7, 2015 12:39 AM
Numwen
Sep 6, 2015 12:30 AM
