2007 Jag X-Type - Oil spraying under hood
Old Apr 9, 2018 | 05:27 PM
shirleycherry's Avatar
Default 2007 Jag X-Type - Oil spraying under hood
Ok I just did a 6 hour road trip and when I got to my destination I had oil dripping from under the hood, on the passenger side under hood soaking the alternator all over the top of the motor even dripping down on the break calibers! I lost 3 qts of oil can anyone help me here where is it coming from??
I need to do this 6 hour trip back home Friday
the photo is a place it may be coming from any ideas
Old Apr 9, 2018 | 06:26 PM
Welcome to the forum shirleycherry,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Apr 10, 2018 | 03:04 PM
astromorg's Avatar
Your photo shows the variable valve solenoid for that bank. It could come from there although it doesn't look like a 3 quarts leak in the picture! Are you sure the sump was full when you started? To fit a new seal, the whole cambox cover has to be removed
The way to find out the source for sure is to spend a bit of time cleaning things up and then, with a full sump of oil, start again, but this time watching carefully! First, is there any leakage from anywhere at idle; if not do a quick run with not too many revs on the clock and check again. If nothing, maybe a longer run with higher revs and check again and so on until the source reveals itself.
Old Apr 10, 2018 | 05:37 PM
Originally Posted by shirleycherry
..... I lost 3 qts of oil can anyone help me here where is it coming from?? .....
That is a HUGE oil loss - 50% of the contents. I can't see that resulting from a seal failure on an area that is not under pressure feed.
Follow astromorg's advice to get everything cleaned down, refill to level and check for the source.
Old Apr 10, 2018 | 06:02 PM
NBCat's Avatar
Has any work been done to the front of the engine?
For the engine to lose that amount of oil, there would need to be a failure of the front crankshaft seal or one of the gaskets to the timing cover. The VVT solenoid grommet in the photo is not going to cause a leak of that magnitude unless it was completely missing.
Follow the instructions outlined by Astromorg and report back. Use a mirror with a torch (flashlight) once everything is cleaned up to see the lower part of the front timing cover.
Old Apr 16, 2018 | 10:21 AM
Default Thank you for all your advice
Ok I the solenoid in the photo got replaced because the seal was completely missing. Cleaned the complete engine and since have had no oil leaking or going down it is staying full. But the check engine light came back on so not sure if problem is fixed
Old Apr 16, 2018 | 11:51 AM
avern1's Avatar
It might be related in that a sensor was damaged by the oil. But, most likely it isn't. Take the vehicle to a place like autozone or any auto store that reads the codes for free. Get the code read out and post the numbers and we can help with diagnosis.
JOREL.VASCO.REALTOR
Mar 24, 2018 09:22 AM
JOREL.VASCO.REALTOR
Mar 23, 2018 01:13 PM
Apollo-XJ8
Mar 16, 2018 06:48 AM
John Fox
Sep 12, 2012 07:33 PM
Mohammed Marwan
Mar 15, 2012 12:51 PM
