6 cd changer?
Old Aug 3, 2006 | 07:05 PM
racerx82's Avatar
Default RE: 6 cd changer?
Try e-bay for your cd changer, look under s type and X.....both use the same head and have the same connections. Seen one the other day for 150 i think. If you go Jag, they now have a new model that replaces your arm rest with the CD changer (if your into it) I rather keep my arm rest.
Congrats on the tint.
________
DEPAKOTE SETTLEMENT
Old Aug 4, 2006 | 07:46 PM
racerx82's Avatar
It's not in the tire compartment. Open the trunk, and on the left side, remove the panel cover, somewhat cumbersome, and you will, or should see the fiber optics and 2, 12 or 28 pin connectors...if you don't see the connectors, than your car doesn't have it.
If you have the connectors, then that means the bracket studs are there also. When you find and decide to buy the changer, you should ask for the brackts also. It will make the installation a painless one.
Good luck
________
MARYJANE
captbob73
Oct 24, 2015 05:49 PM
mrsteady
Sep 20, 2015 03:38 PM
texaspete
Sep 10, 2015 08:34 AM
al_roethlisberger
Sep 9, 2015 09:14 PM
