ABS and brake warning lights on
Old Sep 6, 2019 | 02:38 AM
Ken 2's Avatar
Default ABS and brake warning lights on
How to determine whether is is the speed sensors or the ABS unit
Old Sep 6, 2019 | 06:07 AM
Thermo's Avatar
Veteran: Navy
Ken, get the codes read. If you are getting a C11X5 code (where X is 4, 5, 6, or 7, which will tell you which wheel is acting up), then this will confirm a bad wheel speed sensor.. No codes or other codes would be pointing towards a bad ABS unit.
Old Sep 6, 2019 | 02:32 PM
Dell Gailey's Avatar
Btw, you'll need a unit that reads "c" codes for a Jag. A less expensive "elm" type will not do it.
Old Sep 8, 2019 | 01:34 AM
JagQ's Avatar
[QUOTE=Dell Gailey;2123309]Btw, you'll need a unit that reads "c" codes for a Jag. A less expensive "elm" type will not do it.[/QUOT
Look for an OBDII scanner that has the 1.5 version and PIC18F25K80
Viecar Bluetooth is fairly cheap, like $19 on amazon. It will read C codes. I originally got the Bluetooth because i was using my mobile to run Torque, and when i connect to the OBDII using wifi then i would loose connectivity to internet , With Bluetooth, i was connected to internet via mobile data and to OBDII via bluetooth,
Later on i got the Android 10" Mirror for my x type and now i can use either one, but bluetooth tested faster for me, i can see my information in (almost) real time,
Old Sep 8, 2019 | 12:34 PM
Ken 2's Avatar
Thanks. I suspect it is a wheel speed sensor
Old Sep 8, 2019 | 12:36 PM
Ken 2's Avatar
Thanks. Good point
Old Sep 9, 2019 | 12:37 AM
JagQ's Avatar
I tested the symptoms yesterday,
Start the car, drive under 40 MPH, the light did not come on.
Once you go over 40 MPH, the light triggers.
I have error codes on my OBDII for all 4 sensors, although only one is bad, i know for a fact, the front left.
This is the OBDII scanner i am using
showing @ work
Reading C codes
jag01xk8
Dec 14, 2017 02:15 PM
Qwkslva
Mar 25, 2015 08:55 PM
chrisp1981
Jan 31, 2013 06:33 PM
richard thomas
Jan 13, 2013 06:12 PM
