Abs light and dsc light on
Old Jun 30, 2021 | 12:37 PM
Tiff's Avatar
Default Abs light and dsc light on
I'm head fried, I had 2 new wheel bearing's and 2 new ABS sensor's and the 2 light's came on. Took it back and had another 2 wheel bearing's fitted and still got the same problem. These are the fault code's.
C1a78-04
C1a91-14
C1A94-15
C1A95-29
Old Jul 1, 2021 | 10:23 AM
Thermo's Avatar
Veteran: Navy
From the looks of things, your wheel bearings were either installing backwards (yes, this is possible) or the bearings that you bought do not have the reluctance ring inside of it. This will result in the wheel speed sensors not seeing the wheel turning, which will cause the faults that you are seeing.
Old Jul 1, 2021 | 10:31 AM
Tiff's Avatar
Default Abs and dsc light on
Thanks for your help, I up date you when they are changed.
blackonblackXtype05
Jan 11, 2017 10:45 PM
innzane
Apr 3, 2016 08:43 PM
Samantha
Apr 3, 2013 05:12 PM
03JagSType3.0
Sep 25, 2012 08:32 PM
