AC blows warm at idle - cold at 1500 rpms and up
Old Apr 3, 2012 | 01:59 PM
Joe Jupiter's Avatar
Default AC blows warm at idle - cold at 1500 rpms and up
I have a 2004 X-Type Jag and live in South Florida.
The AC blows warm at idle and then gets cold at around 1500 rpms. If I cruise at this 1500 or above the car is comfortable.
Yet when I slow down the air temperature gets quite warm. This seems abnormal to me and I am looking for some advice............specifically anyone who has experienced the same thing and solved it.
I've had the freon taken out and replaced.
Many thanks.
Old Apr 3, 2012 | 02:55 PM
pab's Avatar
pab
I think that is what the TSB (i.e., JTB00183 I think...), mentioned a couple of times, refers to?
Jaguar: Grace, Pace, and Space - Sir William Lyons
Old Apr 3, 2012 | 04:46 PM
RealmCenter's Avatar
There were some compressor delivery valve issues, relatively easy fix if you have access to an A/C machine. A few had orifice tube issues also. I'd start by checking the charge weight, high & low side pressures.
Old Apr 3, 2012 | 05:15 PM
I think pab is on the right track.
Joe, Google the TSB as you won't be able to open forum attachments, maybe an intro is in order to get over that hurdle?
Old Apr 4, 2012 | 10:29 AM
Okay Thanks much. Found the TSB and read it. Talks about degradation of control valve operation preventing the system from delivering full functional potential.
TSB shows modification for replacing the compressor valve spring.
Sounds like a logical direction to go in to me...............
Think I will pursue this first............
Appreciate the input from you all!
Old Apr 4, 2012 | 12:05 PM
You don't actually replace anything, just reverse valve and spring locations.
Old Apr 4, 2012 | 12:59 PM
pab's Avatar
pab
Glad I could help :-)
Old Apr 12, 2012 | 11:09 PM
93XJR-S's Avatar
old post, I know but did this TSB resolve the issue? I have an 03 ST-R that has exactly the same problem at idle, my high speed fan wont come on though either
PlatinumJag
20
Oct 2, 2020 02:23 PM
Malihide
Apr 2, 2016 04:05 PM
ccfulton
Sep 20, 2015 05:15 PM
explorer364
Sep 11, 2015 05:44 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
