Adding aftermarket Amp to x-type
Old May 13, 2010 | 02:08 PM
Bumble's Avatar
Default Adding aftermarket Amp to x-type
Hi,
I've been looking through all the threads and can't find an answer to my question, hopefully someone will provide me with a quick answer.
I have an X-Type Estate (Station Wagon) 2005, with the standard factory head-unit. It's not the premium system but has got cd-changer etc.
I have a Phoenix Gold Amp and sub-box that I want to wire up.
The amp used in the Premium system uses an optical cable to connect to the amp.
I only want to power the sub from the amp as the rest of speakers are ok.
I know I could get a speaker to RCA (phono) converter easy enough, but that would mean splicing into the rear cables (as I want to continue using these). Is there an adapter/harness/copnverter anyone knows of that would let me use the optical connection instead?
Old May 14, 2010 | 10:48 AM
DavidMoo's Avatar
I used an aftermarket amp, have a look at my premium-ish sound post. I added a hi-lo converter to the wiring loom of the radio to get the RCA output,
Old May 14, 2010 | 10:51 AM
DavidMoo's Avatar
Wiring Info
https://www.jaguarforums.com/forum/s...ad.php?t=36128
amp and speaker info
https://www.jaguarforums.com/forum/s...ad.php?t=36583
hafren
23
Jan 3, 2025 11:26 AM
Rivguy
Nov 13, 2022 02:55 AM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
1LowCat
Sep 14, 2015 07:51 PM
tvholden
Sep 12, 2015 11:13 AM
