Air conditioning
Old May 9, 2016 | 10:20 AM
Max007's Avatar
Default Air conditioning
Hi
I have a X-Type diesel 2004 I need help please I need to know if I have to discharge the air con to renew the pressure switch under the inner wheel
thanks andy
Old May 9, 2016 | 10:34 AM
Andy,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
Old May 9, 2016 | 12:53 PM
DPK's Avatar
DPK
Yes
Old May 11, 2016 | 12:08 PM
Max007's Avatar
Hi just a update yes you can change the pressure switch with out discharge there is a valve in the pipe
Old May 11, 2016 | 12:32 PM
DPK's Avatar
DPK
Are you sure Max?...Just wondering now myself..I never had to change the X-type version out..But a few others of different car breeds I did and it was not on top of a check valve (Schrader type fitting) and I had to dump all the charge to get it off to change.
Old May 11, 2016 | 01:03 PM
Max007's Avatar
Hi yes I have just removed and replaced the pressure switch thats under the of inner wing as you remove you here a small his like when you remove a tyre gauge. This is on my 04 x type diesel
Old May 11, 2016 | 02:09 PM
DPK's Avatar
DPK
Good to know..thanks Max
Jack Mathews
General Tech Help
May 28, 2016 11:34 AM
Sublyminal
May 9, 2016 06:12 PM
PaulParanoia
Apr 12, 2016 05:42 AM
Roger Mabry
Apr 11, 2016 07:38 PM
VictorLEE
Apr 11, 2016 12:34 AM
