Air flow meter
Old Jun 4, 2016 | 06:14 AM
PHIL K's Avatar
Default Air flow meter
Can any one tell me the order of the wiring colors that go into the plug for the air flow meter on a 2.0l diesel x type jag 2004 sport the middle two are broken
Old Jun 4, 2016 | 09:20 AM
Welcome to the forum PHIL K,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jun 5, 2016 | 06:38 PM
Rchiv's Avatar
Hi Phil, The four wires to the MAF are White/green, White/Blue, Brown/Blue and Brown/Blue.
If you cannot splice wires to the plug and you have difficulty in finding one for the Jag then the Ford Mondeo has the same which you might be able to obtain from a scrapper. Ensure you get plenty of the harness.
Roger
Old Jun 5, 2016 | 07:59 PM
PHIL K's Avatar
Thanks it was the center two i was unsure of, the rear one being white blue i then have put blue brown then brown light blue and green white to the front i have just driven the car to London and back the way up the check engine light was on but on the way back the light was extinguished so they must be correct but i will source another plug as i had to cut this one back to solder in the wires
mark a l
Mar 7, 2020 03:53 PM
Florida_Pilot
Aug 25, 2016 11:44 AM
JaneB3
30
Apr 13, 2016 01:11 PM
Eel
Apr 5, 2016 05:25 PM
phil51
Mar 25, 2016 08:18 PM
