Airbag light on
Old Feb 2, 2010 | 09:03 PM
pnyklr's Avatar
Default Airbag light on
How can I get it checked is the dealer my only option?
Old Feb 2, 2010 | 10:13 PM
Jaggyx's Avatar
what do you mean the airbag light is on? so you mean that little light on the airbag itself on the wood trim or some other light on the dash? that light goes off to show that the airbag is off. I believe the x types had some sensor that detects the weight of the passenger to see if an airbag should be on or off. If the light is on when you have a child in the front seat everything is in order. but if the light is still on when you have a 150 pound man in the seat then you have a problem. try to do some more research about it by using the search function.
Old Feb 3, 2010 | 07:59 AM
pnyklr's Avatar
not the passenger one this is actually the one located within the gauge cluster
Old Feb 3, 2010 | 10:03 AM
Jaggyx's Avatar
oh, then i couldnt tell you. sorry about that
Old Feb 3, 2010 | 01:49 PM
Real_Tech's Avatar
Most aftermarket scanners will not be able to access air bag codes on your Jag. you could try calling some local shops and see if they may be able to do it. If you can find a European car specialist that may be your best bet if you're dealerphobic.
Old Feb 3, 2010 | 02:05 PM
pnyklr's Avatar
ok will try to have it looked at next week when I get the window fixed
Old Feb 5, 2010 | 02:24 PM
Real_Tech's Avatar
Default Codes can be flash checked
Sorry, I must have had a brain fart. here is copy of bulletin with flash code diagnosis for X-Type.
File Type: pdf
Old Feb 5, 2010 | 10:00 PM
pnyklr's Avatar
it seems to flash code 28
Old Feb 7, 2010 | 11:44 AM
Real_Tech's Avatar
Default Knee bolster
If the code is correct that would be the knee bolster air bag. I don't think I have ever seen a problem with the knee bolster on any X-Type. The bolster is the panel right below the steering column where the drivers knees would be. That panel is an airbag. The only problems I have seen are disconnected when installing accessories and forgeting to reconnect.
Old Feb 7, 2010 | 11:51 AM
pnyklr's Avatar
I counted two flashes then eight a couple of times I dont know of any aftermarket accessories in the car at all though
Jpav27
Jul 31, 2022 06:43 AM
XJsc-guy
Nov 23, 2015 01:56 PM
redrover41
23
Sep 25, 2015 01:33 PM
34by151
Sep 6, 2015 05:14 PM
AL NZ
Sep 4, 2015 08:39 PM
