Aircon woes
Old Jul 9, 2018 | 06:48 AM
andybsmith's Avatar
Default Aircon woes
Hi all my 2.5 AWD manual 2004 xtype has a distinct lack of Aircon, compressor seems ok in that the low pressure circuit value drops when the stepper clutch cycles, however when feeling around the condenser the only area that gets warm is the immediate area where the pipes enter and exit, one of the pipes (high pressure?) gets quite warm the other stays at ambient (low pressure?) My question is do I have a blocked condenser, presumably these things have a bypass to prevent excessive pressure in the system should a blockage occur?
Old Jul 9, 2018 | 11:54 PM
Dell Gailey's Avatar
Heed #4 post =
https://www.jaguarforums.com/forum/x...ng-all-202014/
Old Jul 12, 2018 | 02:58 AM
andybsmith's Avatar
Thanks for the advice Dell, just a bit curious, could an under performing compressor cause the symptoms my Aircon has?
Old Jul 14, 2018 | 11:42 AM
andybsmith's Avatar
Tried the valve/spring fix and now have Aircon again, I must admit I was sceptical about it but that tip has saved me a shedload of money, a big thank you to you Dell!
mojorising
Oct 13, 2009 09:46 PM
derkins
Sep 5, 2009 12:04 PM
mottisfontmike
Jun 5, 2009 11:54 AM
rapter
Feb 22, 2009 01:07 PM
nicks
Sep 12, 2008 12:09 PM
