Alternator light goes on and off, help!
Old Sep 10, 2011 | 09:51 AM
catwhit's Avatar
Default Alternator light goes on and off, help!
I have a Jag X type 2005 and recently replaced the battery. The alternator light went on, I had AAA who installed the battery check the numbers and all ok. Light went off and came back on two weeks later for a brief period.
What should I do and what does this indicate? I was told best to bring it back in when the alternator light comes back on? Hoping its just a fuse!
Old Sep 10, 2011 | 10:30 AM
The battery cables can cause problems on the X Types, maybe you can get them checked / changed.
You will find more info if you serach.
Old Sep 10, 2011 | 04:33 PM
Thermo's Avatar
Veteran: Navy
catwhit, like Norri said, a lot of the time it is the battery cables on our X-Types that will give us problems like this. If you can do the work yourself, you should be able to get new cables installed for around $100 (both positive and negative cables). Not that hard of a job to do. If that don't fix it, could have a problem with the alternator, but from past experience with the cars, the alternators are pretty stout pieces in these cars and to have one go bad, you would be one of the first. Look at the battery cables first.
On a side note, we do ask that you do an introduction in the "New Member" forum. We are a friendly bunch and we like to get to know each other. Please stop by, tell us a little bit about yourself. You will also get to learn who the movers and shakers are around here. you may even find it a bit beneficial too.
Old Sep 11, 2011 | 08:54 AM
catwhit's Avatar
Default alternator light on and off
thanks for the replies. AAA checked the battery connection again but will take the car in to a service center and hope for the best!
Will go to new member sight as well.
Jpav27
Jul 31, 2022 06:43 AM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
Mosers63
Sep 6, 2015 02:53 PM
jaguarbill
Sep 5, 2015 11:43 AM
