Another p1603 code
Old Jan 24, 2021 | 04:14 PM
Brice's Avatar
From: Northern California humboldt county united states
Default Another p1603 code
I have scoured threads blogs post and what have you hut here is my issue. Just purchased 04 xtype 3.0 with 60,000 dash says gearbox fault obd reads p1603 eeprom and p1000 car shifts in all gears and drives fine a little whine coming from under maybe tyranny not sure .and if I clear codes the p1603 goes away but returns when I turn the car back on I have tried reseting car (disconnecting battery with key off then letting sit for half hour ) I checked tcm and ecu for signs of water . I'm at a loss
Old Jan 24, 2021 | 04:24 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...function-2009/
https://www.jaguarforums.com/forum/x...e-3-0l-207762/
Old Jan 24, 2021 | 09:39 PM
Brice's Avatar
I have read both and neither seem to apply .I can shift without issue u have reset via obd and hard reset my cruise still works .idk I'm going to pull my battery tonight and put on c h arge to see if that does anything
gkubrak
Jul 23, 2015 08:57 AM
aviaction
Oct 15, 2013 07:05 AM
spitfire62
Aug 23, 2013 03:16 PM
cosworth
Dec 19, 2008 01:19 PM
dubydogg
Jul 17, 2007 11:39 AM
