Anti-theft enabled
Old Jan 12, 2019 | 02:24 PM
rcinc01's Avatar
Default Anti-theft enabled
2007 Jaguar X-Type anti theft turned on. was trying to change car radio. now car wont start. receives power but wont turn over. thinking antitheft system kicked in. is there a way to disable it?
Old Jan 13, 2019 | 05:33 PM
Welcome to the forum rcinc01,
I've moved your question from X150 to X-Type forum. Members here with the same model will be able to help.
Old Jan 14, 2019 | 02:13 AM
JagV8's Avatar
No realistic way to disable it, but if it's in anti-theft you will have codes to say why. What are they? Also, likely flash code on the PATS light.
Old Jan 14, 2019 | 01:17 PM
Alfadude's Avatar
When you say you were trying to change the radio do you mean that you were physically removing the radio itself to put in another? If so, if the radio was out and you tried to start the car, that is your problem. I don't recall the sexact pecifics of the situation, but the radio is connected to the internal sysyem of the car and if it is out the "loop" in the sysyem is not complete. If that describes your situation if you do a search on here I'm sure you can find more about it.
mikebaker3
Jan 14, 2019 03:13 PM
LoudHogRider
Jan 14, 2019 10:17 AM
FType17
Jan 3, 2019 12:50 PM
goodpoint
Dec 19, 2018 03:23 PM
