Antifreeze leak and knock sensor
Old Feb 28, 2024 | 11:58 PM
Spikepaga's Avatar
Default Antifreeze leak and knock sensor
Hello all,
After a long absence I am trying to catch up on some deferred maintenance. I was my late grandmothers caretaker until recently and I just let everything go to hell in my X type , Including three sun damaged panels I will have to have repainted.
Beginning with the things I can do myself ; I have a few coolant leaks, I just got thru replacing the pump, and have also removed the old broken coolant tank and ordered a new one . .
I also have coolant puddling around the water inlet spout , so I have ordered the two seals necessary for that (8 and 9 in the diagram)
But since I am also having an occasional knock sensor code come up……and will be replacing the sensor too and I was thinking I should replace the gasket to the metal hose that has to be removed to access the knock sensor….only I can not figure out which one it is on the diagrams so I can order said gasket.
Does anyone know what this gasket is? I would hate to replace the knock sensor to find the hose above it is leaking.
Thanks!!
tjankovs
Nov 22, 2025 01:39 AM
Z07Brandon
Nov 24, 2018 05:38 PM
Peter14
May 27, 2018 08:13 AM
josh_77073
Sep 29, 2013 04:57 AM
Karaudio23
Nov 18, 2012 01:14 PM
