anyone know which fuse if for the right headlight?
Old Jan 16, 2008 | 02:31 PM
matl's Avatar
Default anyone know which fuse if for the right headlight?
Hi, i dont have my owners manual and the fuses dont come with a description. My passanger side headlight isnt workin, i replaced the bulb with no luck and now i want to check the fuse but dont know which it is. Does anyone know?
thanks
Old Jan 16, 2008 | 03:01 PM
SpartanX's Avatar
Default RE: anyone know which fuse if for the right headlight?
Low(dip) beam Light Fuse
F16 mini Left Hand 20 AMP Yellow
F17 mini Right Hand 20 AMP Yellow
Engine compartment, 2nd row from the left of mini fuses. It'll be the 3rd(F17) and 4th(F16) from the bottom of that row.
Hope this Helps..
SpartanX
Old Jan 16, 2008 | 05:40 PM
Size:  6.3 KBName:  X6JYMSAAB5.jpg
Size:  6.1 KBName:  AudiX6JYM-2.jpg
Nice assistance for the newbie Spartan............nice one mate
Jim
Old Jan 16, 2008 | 07:11 PM
FactoryJaguarTech's Avatar
If your X-Type is pre 2004 it could also be the connector going to the bulb has melted. If fuse is ok, pull connector back off the bulb and look to see if it melted. There is a fix we do at the dealer by soldering new connector to it with a seperate ground soldered to the lamp casing.
Old Jan 17, 2008 | 09:52 AM
matl's Avatar
ORIGINAL: SpartanX
Hope this Helps..
SpartanX
that fixed it, thanks for helping a noob out
Old Jan 17, 2008 | 01:09 PM
SpartanX's Avatar
ORIGINAL: matl
ORIGINAL: SpartanX
Hope this Helps..
SpartanX
We all were noobs at some point
Glad I could help...
SpartanX
Old Jan 17, 2008 | 03:38 PM
aquill1's Avatar
Nice fix sparty...keep up the good work! Perhaps you also can get one of those snazy tech certified symbols below your avatar! In know I want one! There's another guy on here FJT that has had that problem and the dealer (i think) already fixed it once but it melted again...
Old Jan 17, 2008 | 04:18 PM
SpartanX's Avatar
ORIGINAL: aquill1
Ha! I may be changing my avatar to a little gold bar soon...I'm almost 100% sure that I'm going in the Army to be an Officer.
Old Jan 17, 2008 | 07:26 PM
aquill1's Avatar
Well have a good one! Keep your head up!
aode06
Jul 28, 2023 02:26 PM
hoodun
Nov 20, 2022 02:35 PM
jagent
Jun 5, 2022 02:18 PM
sedonajag
Oct 8, 2015 07:38 PM
gunlocators
Sep 30, 2015 08:05 AM
