Anyone using this oil?
Old Aug 26, 2016 | 10:34 PM
wyxtype's Avatar
Default Anyone using this oil?
I saw this at Walmart the other day and was curious to see if anyone had used it.
Old Aug 27, 2016 | 01:05 AM
JagV8's Avatar
What I do is look in the owner's manual for the spec. I don't have your car but I suspect that oil will not match your spec.
Old Aug 27, 2016 | 02:30 AM
plums's Avatar
He didn't ask for the spec ... only whether anyone had used it.
Yes, it's been in my crankcase for a few months and the
engine hasn't blown up. Nor has it used any oil or make
any unusual noises. I have full confidence in that particular
oil.
It's a light violet colour when new.
Old Aug 27, 2016 | 04:39 PM
hlgeorge's Avatar
It's a great oil to use, but be sure you use the recommended weight.
Old Aug 27, 2016 | 04:56 PM
Mikey's Avatar
Sure millions of people have used it. Advertising can be very persuasive. What's wrong with the oil you've already got?
Old Aug 27, 2016 | 05:33 PM
philed's Avatar
Default castrol edge
hi, im over here in nz and have my oil changed at the dealer he uses castrol edge pro not sure if this is the same stuff as you have, looks the same though
Old Sep 1, 2016 | 12:34 PM
wyxtype's Avatar
The owners manual lists a 0w-40 as a weight than can be used. I've used 5w-30 Pennzoil Ultra Platinum in the past but can no longer find it in town.
Old Sep 1, 2016 | 03:01 PM
Thang Nguyen's Avatar
Two difference things in the oil are: Viscosity and synthetic or regular, otherwise there is no difference from brands. But if your car is old (@100K miles) you should use a little heavier viscosity for better seal the gaps on the worn parts as cylinders and piston walls.
Leeper
31
Jan 3, 2017 03:40 PM
Americain
Aug 24, 2016 08:34 AM
davidboger
Aug 23, 2016 10:27 PM
Jaguar Forums Editor
Jaguar Press release
Jul 15, 2016 02:48 PM
PinnacleWax
Detailing / Car care
Jun 17, 2016 02:06 PM
