Auto headlights not working
So I've only recently acquired my X-Type, and playing with all the controls, I've found my auto-headlights don't work, although the headlights do when manually switched on.
Any suggestions on where to start looking to fix?
On a side note, does the 2005 X-type come with an auto-dimming rear view mirror? I suspect I have one, but it is non-functional.
Thanks in advance!
Thanks in advance!
I'll try adjusting the button beneath the rear-view mirror and see if there's any change. I've toggled it a few times. Presumably, when it's depressed, it's on auto-dimming mode. Otherwise, is there a manual way to dim the mirror when some inconsiderate person behind doesn't understand the concept of blinding the driver in front with their full beams?
Just revisiting this again.
I read the post about taking the rear view mirror apart, but is it likely to be a fault there in the sensor? If so, how would I tell?
As of now, my rain sensing wipers work (and I suspect the sensor for this would also be in the rear view mirror), but neither the auto headlights nor auto-dipping rear view mirror work.
The mirror is photochromatic, dims from light, darker the brighter the light. The fluid in the mirror has been dubbed "dragon's blood" by Jaguar. If it leaks (does sometimes) it eats everything it touches including plastic. I found a post on a different model, but it should give you enough guidance to help if you decide to try and remove and fix or refurbish your existing one rather than just replacing it.
https://www.jaguarforums.com/forum/x...acement-17719/
