Automatic Tranny Fluid change
Old Feb 1, 2008 | 07:48 PM
H20boy's Avatar
Default RE: Automatic Tranny Fluid change
^^ you guys are funny posting back to back like that! [sm=icon_rofl.gif]
Reading the sigs...
Preventitive Maintenance is a whole lot cheaper than Corrective maintenance. "
vs
"If it ain't broke, don't fix it!!!"
Oh the confusion...
Old Feb 1, 2008 | 07:59 PM
Dennis's Avatar
ud
LAUGHIN MY *** OFF!
It is rather ironic ain't it?
Old Feb 2, 2008 | 06:38 PM
Dennis's Avatar
ud
For those of you that maybe thinking about doing the fluid change..
Just be aware that you will have to remove the Battery and Battery box in order to get at the fill port..at least on mine I will..
Old Feb 2, 2008 | 06:45 PM
ancientsanskrit's Avatar
Dennis, would you be willing to make a comprehensive how-to for your fill/drain process?
I'm sure I, as well as others would really appreciate it.
Thanks.
Old Feb 2, 2008 | 06:53 PM
Dennis's Avatar
ud
Sure..I'd love to..
I'll take pictures and narrate them the whole step of the way.
I did the same thing for the Land Rover forum I had, when I did it's tranny fluid change.
Old Feb 2, 2008 | 11:46 PM
Awesome! If you need help hosting it later down the road, give me a holler.
Old Feb 3, 2008 | 12:05 AM
jvegas's Avatar
this is something you are going to do once in a blue moon. why not just put the Jaguar fluid in regaurdless of cost?
Old Feb 3, 2008 | 12:18 AM
  #28
Dennis's Avatar
ud
Well I figure if I bought Jag's fluid it would cost somewhere around $400.00+..verses $80.00 with Royal Purple..and still have the same long life protection from possible failure.
Old Feb 3, 2008 | 12:25 AM
Dennis-
I haven't read far enough into this, however from my experiences w/fill+drains on many automatics, you'll only get whatever is in the transmission oil pan and not the entire transmission.
Is this statement correct? I prefer this method than a more aggressive flush that gets all the fluid out of the system at once. This can be a real shock to the system and I've seen cars w/higher mileage and very poor transmission maintenance kick the bucket w/fresh fluid added so abruptly.
Old Feb 3, 2008 | 12:27 AM
  #30
Precisely. At $50+/qt. You're looking at $450 w/o tax.
Furthermore, I plan on doing this more than 'once in a while.' When I get around it, I'm going to try to get the techs' 'real' opinion on this ordeal. As a premature guesstimate, I think a healthy 30k mile interval is a solid regimen for most trans.
Old Feb 3, 2008 | 12:33 AM
  #31
Dennis's Avatar
ud
Yes that is correct..the remainder is in the cooler and Torque converter..Flusing is okay too, but you have to have one of the inline flushers..and may cause too clean of fluid all at once..Don't know if this would be a concern with these tranny's with high miles on it, but I have heard trannys with conventional fluid with high miles it is best to just drain and refill only, as flushing breaks loose sludge deposits..I will put a 100 miles on the first drain and re-fill and then drain and refill it again..this way I'll be getting at least 75% of all the old fluid out.
Old Feb 15, 2008 | 08:45 PM
  #32
ruslan35's Avatar
Dennis,
What ATF did you use? I am getting ready to change my trany fluid on 02 2.5 and cant figure out what fluid to use.
Thanks for the help!
Old Feb 15, 2008 | 08:56 PM
  #33
ruslan35's Avatar
Just found this post on search in google. At the same time Dennis replyed to my post. Will wait for more info on fluid and pictures. Goodluck!
Old Feb 15, 2008 | 10:18 PM
  #34
Dennis's Avatar
ud
Hey Ruslan..As I mentioned in the first part of this Thread..I will more than likely be going with Royal Purple MaxATF Multi-spec. I have yet to find a single technical contridiction to using it.. a friend that works at an O'Reilly's, can get it for me for $9.00/qt.
***CHANGE OF PLANS>>I will not be using anything besides the official JATCO fluid..see below)
Old Feb 18, 2008 | 02:15 AM
  #35
ruslan35's Avatar
Hey Dennis,
Maybe this will help you a bit: http://jagmotorproject.blogspot.com/...al-fluids.html
Old Feb 18, 2008 | 11:10 AM
  #36
Dennis's Avatar
ud
ORIGINAL: ruslan35
Hey Dennis,
Excellent information Ruslan Thanks....this info and what else I've been researching on the JATCO transmission fluid leads me to believe that the use of any other product besides the Idemitsu K17 - Jatco 3100 PL085..would be fools play on my part..so..right now, I will NOT be changing my fluid unless I can find this JATCO fluid at some price a whole lot cheaper than my dealer sells it for ($50.75/qt.)
Old Feb 18, 2008 | 09:02 PM
  #37
Dennis's Avatar
ud
I give up!!..Is there any place out there that a person can buy this Jatco 3100 PL085 besides from the dealer??..surely there is a wholesaler out there somewhere..Any of the JAG TECHS here know?
Google turns up nothing..except this thread and a few Roadfly threads..
Old Feb 19, 2008 | 12:05 AM
  #38
Supralative's Avatar
I am with Dennis on this fluid also hehee.
I would also like to pick up this stuff
to do tranny flush, along with transfer case and rear diff.
Hopefully you will find something!!!
Old Feb 19, 2008 | 04:55 AM
  #39
FactoryJaguarTech's Avatar
I can probably get it for you cheaper than that. Just don't know how to ship liquids.
Old Feb 19, 2008 | 08:50 AM
  #40
jvegas's Avatar
i think you can use UPS for that.
