Back up sensors
Old Dec 13, 2010 | 11:56 AM
seanshamrock0000's Avatar
Default Back up sensors
out of no where, my reverse sensors dont work, but the first time i put the car in reverse after turnign it on, i get a long beep. anyone experience this?
Old Dec 13, 2010 | 11:58 AM
sidewalkman's Avatar
yes, mine works flawlessly for a long time then a long beep, then nothing.
Old Dec 13, 2010 | 04:54 PM
Thermo's Avatar
Veteran: Navy
Sean, the long beep that you are hearing is telling you that you have a problem with the back up sensors. What you can do is to set the e-brake, turn the car on to the RUN position (engine is not turning) and then shift the car into reverse. Then you can get out of the car, put your ear next to each of the back up sensors (little round pieces under the bumper) and listen for a high pitch squeal/clicking. If you hear the clicking/squeal, the sensor is good. No sound, sensor is bad and needs to be replaced.
If you need help replacing the sensors, let me know. IT is pretty easy once you know what you are doing. Also note that the middle 2 sensors are different than the outer sensors. So, if you need a new sensor, make sure you get the correct one.
Old Dec 13, 2010 | 07:27 PM
pretty much as Thermo posted but here is the park aid diagnosis from the X type quck FAQ link thread
https://www.jaguarforums.com/forum/s...ad.php?t=10367
RoyLittle0
May 25, 2023 02:38 AM
KarimPA
Sep 12, 2015 08:15 AM
tberg
Sep 7, 2015 07:32 AM
Corycarlo
Sep 5, 2015 11:41 AM
KarimPA
Sep 3, 2015 07:32 PM
