bad water pump
Old Feb 5, 2013 | 09:29 PM
mobilextc's Avatar
Question bad water pump
Will replacing the water pump be an easy project to do myself. My mechanic skills Good but not advanced.
Old Feb 5, 2013 | 10:19 PM
Nardoswiss's Avatar
It's an easy job if I'm not mistaken. You've got to drain the coolant system (but flushing antifreeze is not a bad idea anyway) and then it's pretty straightforward.
Oh and you've got to remove the battery to get some room to do the job.
Old Feb 6, 2013 | 12:11 AM
Bud Tender's Avatar
Once you get the battery and battery box out of the way you will have all the access you need. While you are at it you might as well change the drive belt, it's a mini serpentine kind of thing. Looks a little like it should be driving a sewing machine. I think I paid $12 for one.
Old Feb 6, 2013 | 11:56 AM
Thermo's Avatar
Veteran: Navy
mobile, if you can rotate your tires, you can do a water pump on this car. LIke was mentioned, you need to remove the battery. Then you lift up on the tensioner and slide the belt off. From there, you undo 4 bolts holding the pulley to the water pump. Finally you undo like 8 bolts and the pump is ready to be removed. Install is the reverse process.
After you do it, you will be questioning why you waited so long because it is so easy. I put it right up there as being easier to do that a water pump on a late 70's RWD car with no emissions stuff on it.
Old Feb 6, 2013 | 12:15 PM
mobilextc's Avatar
Thanks all. I had to take my car in to replace alternator. But looking at the water pump looked like something I could handle. So thanks.
Wahooesprit
Dec 23, 2019 02:01 PM
ccfulton
Sep 20, 2015 05:15 PM
Jaiello21
Sep 14, 2015 09:42 PM
1964Daimler
Sep 9, 2015 11:28 AM
mrplow58
Sep 9, 2015 11:27 AM
