bad water pump symptoms..
Old Nov 18, 2010 | 09:50 PM
afonda's Avatar
Default bad water pump symptoms..
Hi. will a bad waterpump leak coolant?
How do you know the water pump is bad?
Old Nov 19, 2010 | 05:18 AM
Thermo's Avatar
Veteran: Navy
afonda, yes, when a water pump goes bad, it tends to take the front seal with it, so, it will start to leak out around the shaft. in some cases, if the impeller gets too corroded/eaten up, you will start getting overheating problems when driving down the highway but the car will be fine in town.
If you need more help, let me know. By the way, I'm about 90 minutes away from you on the other side of the 301 bridge. So, if you need some help......
Wahooesprit
Dec 23, 2019 02:01 PM
ccfulton
Sep 20, 2015 05:15 PM
Jaiello21
Sep 14, 2015 09:42 PM
1964Daimler
Sep 9, 2015 11:28 AM
mrplow58
Sep 9, 2015 11:27 AM
